I sadly came to the conclusion that 1) I'm not getting any younger, 2) my tractor "toys" are not getting any lighter, and 3) the number of toys has outgrown the space I designed into my storage shed. As a result changing attachments was becoming a growing issue. I looked at quick hitches, but concluded they are expensive, heavy, and didn't really address the storage issue.
So with my 70th birthday approaching last fall I decided to finally move ahead with a long-standing idea to build dollies for most of my attachments. The photos show the result, which have been very satisfactory. I changing attachments is now much easier. I no longer have to get the tractor in just the right position, and the tools move easily to make the connections. Implements stacked in front of others is no longer an issue - I can just wheel them aside to get to the one in the rear.
Not having welding tools, I made them from scrap wood, buying only the bolts and casters. I found Caster City very helpful - they have a wide variety of types, and there is a live person who will advise on type, size, and tire type based on weight, floor condition, etc.
Learnings: 1) The 600# chipper is about the upper limit in weight for this approach. Even with heavy duty casters, it's a bit tough to get moving. 2) The one for the tiller is under-engineered. Even with very old hard 2x4s, they are bowing laid flat. They will get reinforced next time I get the tiller out. 3) The fixed upright on the blade dolly is less than ideal. Since I often adjust the top link to get the blade to cut as needed, when I bring it in it always needs adjustment to set on the dolly.
But all in all, they are a big improvement. I no longer hesitate to change implements for a few minutes of work.
Terry
Terry
