Equipment chain sizing
/ Equipment chain sizing #1
SkyePN
Mountains of BC
MF 135
Hello,
Looking at some used grader chains for my tractor and the size is listed as 1600-24 (or 16-24 or 16.00-24) does that mean the chains are 24" x 16' laid flat?
Or that it's for a 16-24 size tire? If so that's a 16" wide tire tread on a 24" diameter rim right?
Thanks
/ Equipment chain sizing #2
No about the chain measuring.
Chain fitment is described by the tire size.
The chain described will fit a 16x24" tire with the tire rim being 24" in diameter.
The chain will be much wider than 16 inches to fit a 16" wide tire as the chain must overlap both sides of the tire.
OK thanks. My tractor has 14.9x24 tires so these will probably fit if I shorten it by a link or two, save me a lot of $$.
/ Equipment chain sizing #4
Maybe... might be too wide and interfere with steering or axle components (if on the fronts)
Rear only and plenty of fender clearance but I'll double check thanks
2019 Dodge Durango SUV (A61574)
2019 Dodge Durango...
Colombo Twin Master (A64119)
Colombo Twin...
Precison Planting Air Compressor (A63117)
Precison Planting...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
Hydraulic Breaker Excavator Attachment (A64194)
Hydraulic Breaker...
CRATE OF UNUSED KUBOTA PARTS & BRACKETS (A64280)
CRATE OF UNUSED...
