epoxy a carburetor float bowl?
/ epoxy a carburetor float bowl? #21
Gottcha.:thumbsup:
OK all done. Here's the bowl with the see-thru drain tube. If there's water or funk getting in the bowl then it flows down in this tube where I can see it and pull the plug, drain it out. The tubing is from a motorcycle shop. It feels like a "harder silicone", doesn't feel like clear vinyl, it's guaranteed to remain flexible. We'll see I guess.
378395d1402122029-epoxy-carburetor-float-bowl-sawmill-bowl-drain-jpg
I put it all back together today. Sawmill engine started on the FIRST pull. Gas in the tank was from November 2013, no stabilizer, just E10 gas from Safeway.
/ epoxy a carburetor float bowl? #23
Looks good... report results. Oh and action pictures of course! :D
/ epoxy a carburetor float bowl? #24
Looks like it might just work. How about putting a barbed shut valve on instead of a plug?:2cents:
/ epoxy a carburetor float bowl? #25
yep.. i'd go that route myself.
/ epoxy a carburetor float bowl? #26
The right sized threaded bolt might a be cheap option too that is already hanging around in your shop. I don't see accessing it much other than an occasional glance at it.
/ epoxy a carburetor float bowl? #27
bolt? plug with a pecock maybee.. but I doubt you want a bolt thread in there...
/ epoxy a carburetor float bowl? #28
I know but I have done this kind of thing in the past... maybe stupid but I thread it in and it always holds in the plastic. Definitely shut off valve is best choice. I was going on the cheap. Sorry.
/ epoxy a carburetor float bowl? #29
i actually thought you were talking about a bolt int he bowl, not the hose.. ie.. a bolt in place of the top barb.. that was why i commented.. ie.. bolt thread in a taper hole. :)
/ epoxy a carburetor float bowl? #30
Yeah same as a simple plug just threaded in the end of the tube. Non threaded plugs seem to fall out or get real hard to pull out... one or the other for sure. I really do like the idea of seeing the contents of the tube.
OK here's the action. A 6x8 beam, 21 feet long. For a shelf in my barn, to hold snowmobiles 6 feet above the ground. Will load them up there with the tractor.
attachment.php
Pretty sure I'll just inspect and drain once a year, if pulling the plug gets tedious every year thats a good idea to replace it with a valve.
