EP 00 oil
/ EP 00 oil #1
rvds
Platinum Member
montreal qc
mf 135
A friend has a craftsman manual transmission that specs EP 00 oil and is not finding it anywhere. I suspect this must be a very common transmission, about 25 years old.
/ EP 00 oil #3
EP 00 refers to the NLGI viscocity grade (EP=extreme pressure, the numbers refer to its relative viscocity, eg. EP 00, EP 0, EP 1, EP 2, etc. The higher the number the higher the viscocity)
An EP 00 is a very light semi-fluid grease. A lot of blenders will make some greases in that viscocity grade as it is specced in various types of machinery, eg,
/ EP 00 oil #4
I used JD corn head grease when rebuilding the Peerless transaxle in my John Deere lawn tractor 12 or so years ago; worked fine for many years
/ EP 00 oil #5
00 grease is usually referred to as Snapper grease in the mower repair business. Used in the old rear end Snapper chain cases. The peerless transaxles normally used either 80W90 or Bentonite grease.
/ EP 00 oil #6
Its always on the shelf at my TSC
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2010 CHEVROLET PICKUP 3500 HD 4X4 CREW CAB (A59912)
2010 CHEVROLET...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61574)
2021 Mercedes-Benz...
Caterpillar Jake Brake Manual (A63117)
Caterpillar Jake...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
