Entry Level Welding Help
/ Entry Level Welding Help #1
DAP
Veteran Member
From Orange County NY to Lincoln County ME
JD LX288 and a B7800
I can do a lot of things, but to my dismay, welding isn't one of them.
Now I DO know welding as a topic is as subjective as picking a tractor, but I'll bet it's not a cheap endeavor (not even considering stock).
So, assuming one obtains some descent instruction, where is a good place to start regarding acquiring a welding setup. I'm looking mainly to be able to make small repairs or set up small components. I read another TBNer who's using a Sears Welder that was in the 200 dollar range.
Just looking for a startin place here ... /forums/images/graemlins/smirk.gif
/ Entry Level Welding Help #2
Up until november last year.. I was a non-welder.. For my birthday.. the wife got me an el-cheapo 70amp stick welder from wallmart.. campbell hausfield brand. Welds with 5/64 and 1/16 rods. was 89 or 99 bucks.. Came with cheapy chipping hammer/wire brush combo.. and cheapy welding shield you have to hold with one hand.
For 19 bucks i bought the tractor supply economy welding combo.. came with a pair of gloves, a decent chipping hammer and a 'real' welding helmet that sits on your head with flip up visor... lets you keep both hands on the torch handle.. great for beginners. I also recomend you finding a brand of rod called 'sure strike' I sware you could run a bead on a piece of cardboard they are so easy to weld with... easy to strike a spark.. and they don't stick. Probably there is a trade off with the material strength of the steel.. etc.. but great to build your confidence and learn with.
You can also usually get a cheapy wire/flux welder from harbor freight and/or wallmart in the 200-300 range.. probably 90 amp.. using flux core wire.. with the option to add a gas bottle to it and become 'MIG'.
Best I can say.. is practice. Smaller welder kits weld smaller stock.. like 3/16. 5/16, and 1/4 When you get better and lear some technique.. you can weld bigger stuff with smaller welder fairly decently.. like 3/8.. by deeply 'V' cutting the parts.. and welding the stock in multiple passes to stitch them together. Gusseting also helps add strength to welds.. that is welding side braces to the object in question.
Have a wire brush you like , and get a cheapy 19$ angle grinder.. that angle grinder will be your friend.. clean up your ground connection.. and then use it to clean up your welds. A famous quote is.. 'that the worse you are at welding.. the better you have to be at grinding..'
I've since used the big lincoln sticp welder at work.. 250 ac/dc and made a real super heavy duty set of middle ramps for my john deer B tricycle tractor... practice helped.
I also just started playing with the 225a lincoln mig at work...wow... I gotta get a wire flux or mig welder... nice not changing rods every 30 seconds of weld time... and no slag to chip off.
My idea was to start small to see if I liked it.. so I only invested 99 bucks in the first machine... My next one will be a better model.
And yes.. welding is an art and a science.... and there are many opinions on it.
Soundguy
/ Entry Level Welding Help #3
You might try looking for a used AC or AC/DC welder. I have a couple older AC welders and they fill most of my needs. Of course a wire feed or Tig would be nice for Aluminum or for thin stuff. I also bought an el-cheapo (69.95) autodark helmet at Harbor freight and really love it. I do recommend learning stick welding first and then move on to TIG and or MIG.
/ Entry Level Welding Help #4
You could start with an inexpensive wire feed welder. However, you will soon find that it will not give you adequate penetration on steel much over 1/8" thick.
That being the case, invest in a decent MIG setup. With it you can use either flux core wire or solid wire with C25 gas. If you have only 110v get a Hobart Handler 135. If you got 220v available move up to a Hobart or Miller 175. The 135 will run about $450, the 175 about $600, and if you choose Miller over Hobart add $100. Both Miller and Hobart are made side-by-side by the same company.
If you want to get informed opinions and expert advise, go to the Hobart welders forum.
Hobart/Miller welding forum
/ Entry Level Welding Help #5
Doug, I'd suggest before you buy anything to visit a real welding supply company in your area. Sears, and lots of other stores, sell some welding equipment, and if you know what you're doing, that may be the best place to buy, but I think you'll be very lucky if you find anyone in those stores who is really a welder and can direct you to the proper equipment for what you want to do. Welding classes at places like commmunity colleges is certainly a good idea, but not an absolute necessity.
Many years ago, I bought my first little gas rig from a welding supply company, took it home, read the books, tried it out, and decided it wouldn't weld, so back to the store. Now had it come from a department store, I might have just gotten my money back; however, at the welding supply store, the salesman took me out in their shop and laid down as pretty a bead as I've ever seen a welder do. /forums/images/graemlins/crazy.gif So much for wouldn't work. I felt like a fool, but he taught me to use that little rig. That would not have happened at Sears or other such stores.
/ Entry Level Welding Help #6
DAP,
I'm no welding genius, actually havn't struck an arc in over 10 years, but I'll chime in anyway. For an inexpensive unit to get started with a lot of folks look at the little flux-core units. Those units have some significant limitations. It depends on the kind of repairs that you plan on, but if you plan to work on tractor implements or that type of stuff, you want to be sure you can make a STRONG weld on the type of material that you are welding. You don't want to trust your LIFE to a weak weld.
It takes a bit more practice to lay a bead with a stick welder, but a decent AC buzzbox can be had for under $300 for a NEW one, and probably for less if you find a used one in your local pennysaver/shopper. If it has only been used for homeowner/hobbyist work, chances are it will be in pretty good shape. A new AC/DC moves up to the $400+ range, but buys you the DC which makes it easier to weld thin materials and a little easier to lay down a smooth bead.
To buy a MIG welder that can penetrate into thick steel in a single pass, you are looking at some serious $$$. Like Soundguy said, there are some ways to build up a strong penetrating weld by beveling your joints, which can allow you to get by with a little less amperage.
My thoughts are:
1. Get a welder that operates on 240 volts. (better penetration)
2. Buy GOOD safety gear (helmet, gloves, etc...)
3. If starting on a budget, look for a used AC/DC stick welder. (cheap, durable, decent penetration)
4. Stick to a name brand (Lincoln, Miller, Hobart)
5. Do a search for welding on TBN, there are tons of other threads about it here.
6. Find someone with experience to give you a few lessons. Check out your local community college or vocational school for a class.
7. Check out some books. There are lots of good books on the subject.
8. Practice, practice, practice... BEFORE you do a weld that you have to trust your life to.
9. Have fun! /forums/images/graemlins/cool.gif
/ Entry Level Welding Help #7
Isn't that the truth.
I don't even know why I'm replyng to this because I'm a terrible welder ... I'm successful at it but it's not pretty. To me, welding is like using 3000 degree superglue.
After getting advice from every welder I knew, I ended up getting a small 110v Lincoln Weld-Pak 100 MIG that runs .035 flux core wire. It's great for small fixits, small projects and thin metal - less than 3/16", it's relatively easy to use and you can haul it anywhere without worrying about 240v availability. Having said that, I am replacing the rusted out deck on a 5' bush hog just now and dearly want a bigger machine with more welding time and capacity. I think I may have to get a stick welder for the bigger jobs but that raises the problem of getting 240v to the worksite as I can't get the the bigger jobs into the shop. Ah well, I suppose I'll have to haul the generator along to run it.
The only advice I can give you about welding is "practice, practice, practice". You WILL get better and oh yes, get yourself that grinder - you'll need it.
I don't mean to Shanghai this thread but would you experienced welders recommend getting a 240v stick or a bigger MIG machine.
/ Entry Level Welding Help #8
I would get a 240V stick. Cheaper and you can use your smaller rig for the light stuff. DC is nicer, but AC will work ok unless you are doing a lot of vertical or overhead welding.
With sickening consistency Bird, you're right on the mark. I sit on a train 10 hours a week. Only a good book can keep me from those fitful train naps.
Question now is .. which book! /forums/images/graemlins/grin.gif
Unfortunately, books usually tell you a little about everything or everything about something. I'm open for suggestions on books too. At least I'll know what I don't know and won't buy what I don't want. /forums/images/graemlins/blush.gif
Thanks Chris ... I'll look into those ranges of machines and get aquainted with this flux core stuff. /forums/images/graemlins/grin.gif
/ Entry Level Welding Help #11
Mig, Tig, Buzz Box. Oxyacetylene welding, Arc, shielding gas, is your head spinning yet Doug? /forums/images/graemlins/confused.gif
I'm the kind of guy that likes to sit down and digest it all, in my own time frame, before I lay out the cash. One of the best reference books that I have ever read that covers all aspects of welding is the "Welders Handbook" by Richard Finch. It puts the information in an easy to understand language of something you can absorb and lets you know what to expect out of each machine from the inexpensive right on up the ladder. Lots of good pictures and charts that you will use the rest of your welding days.
You can find it at eBay for about $15.95 so the price is right. And who knows it just might help you to make the right decision on which welder is best suited for your needs.
Thanks Mike. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
I was hopin for the bombardment though.
I like options! /forums/images/graemlins/grin.gif
/ Entry Level Welding Help #14
The * BEST * deal on books on welding is at https://ssl.lincolnelectric.com/foundation/
and
https://ssl.lincolnelectric.com/lincoln/spmount/store.asp?PID=16&cat=6
(I don't know why they have 2 addresses)
Basically Lincoln Electric practically gives away books on arc welding, etc.., probably for around the cost of printing them. /forums/images/graemlins/smile.gif
Unfortunately, they ship UPS, which means that if you live up in Canada UPS charges (I'm trying not to use the S---- words) more for 'brokerage' than the books will cost, but thats another story. /forums/images/graemlins/mad.gif
/ Entry Level Welding Help #15
I have been welding as a hobby since 1975, starting out with an oxy-actelene torch setup. I used it to mostly build and repair racing motorcycle frames. I then purchased a 240v AC stick welder from Sears. This worked well on heavy gauge metal over 1/4" but was useless on thin gauge stuff like auto body panels. I still have both these units but they only collect dust now unless I have over 1/2" steel or need heat to bend steel.
Once I bought my first MIG setup I have never looked back. MIG's are easier to use (even for the beginner), will weld just about any steel from auto body panels up to steel about 1/2" thick (with multiple passes) and works great with 3/16" to 1/4" walled tubing. I have recently built several tractor implements (landscape rake and dethatcher among others) and did extensive body work on 2 cars and the MIG makes this work a breeze. I have no need yet for the capabilities of a TIG unit.
My current MIG is a 220v Millermatic 175.
/ Entry Level Welding Help #16
Doug, I couldn't tell you what books. The ones I read were the manuals with the little gas rig, later a Lincoln stick welder, and the last was a little 110v Miller de Mexico stick welder. Of course, I've known and talked to a number of real welders in my lifetime, and when I was just a little tyke, my Dad drove a truck selling and delivering welding supplies. There are just so many different kinds and sizes of equipment that I wouldn't know of anything that begins to cover them all. When I bought my first little rig, I thought my father-in-law might be able to help with some instruction; wrong again. He made his living as a welder for the railroad repairing damaged coal cars; said he'd never had anything to do with those little tiny rigs. /forums/images/graemlins/laugh.gif
/ Entry Level Welding Help #17
<font color="blue"> The * BEST * deal on books on welding is at https://ssl.lincolnelectric.com/foundation/
and
</font>
The only problem that I can see is that since these books are all sold by Lincoln they may be a bit biased toward promoting Lincoln products and not necessarily whats best for the individual. The Welders Handbook covers all forms of welding and more than a few different names in the Industry. It is not trying to sell a product as much as the idea of welding for fun. I also think that it may be just a bit easier to digest for a new welder. I have seen a few of the other books offered and I don't think that even engineers need as much technical data that they throw at you.
/ Entry Level Welding Help #18
I'm surprised that no one suggested the most important first step to avoid frustration! Take a community college evening class in stick welding.
Nothing beats having an instructor around. And if you are lucky you can get a pretty good deal on the class, considering that materials and equipment use will likely be included in the tuition.
The class I took was ten 3-hour sessions. It was not as cheap as some have posted here. Around 250 bucks I think. But it was well worth it.
At least for me, who had to work a bit to get up to the zero point!
Like has been said above...practice, practice, practice is what it takes more than anything. That and having an instructor to show you that yes, it IS POSSIBLE to produce a good weld with the equipment in your hand, no matter how impossible that may seem when you are first starting!!!
After taking that class a year or so ago I kicked myself quite a few times for waiting until I was over 50 to start to learn to weld.
You don't have to take a class, as others have said...but I am really glad I did and others here have reported that they were also.
You might also take a look at Hobart welders message board which is a pretty good welding site. /forums/images/graemlins/smile.gif
You are not going to regret learning to weld... /forums/images/graemlins/cool.gif
/ Entry Level Welding Help #19
The book I bought and read, even before I bought my little rig, was the "Haynes Welding Manual". I thought it was a good general introduction to welding and it was relatively cheap. My welder also came with an instructional video that was helpful. Also, I think Northern Supply now carries a series of welding videos for about $25 each. I haven't seen them yet but that may be my next move. Finally, I'm in the process of checking out our local Community College for a welding class. I'll learn to lay down a decent bead if it kills me.
/ Entry Level Welding Help #20
The books aren't biased. Obviously, they use photos of Lincoln equipment, when they use photos of equipment, but for the most part they talk about welding, not the equipment.
So, they talk about striking an arc - not whose electrodes to use and so forth. Most all photos/illustrations just show the material, filler, rod, whatever, and don't even deal with the equipment.
You can get hardcover textbooks for $5 to $12! At those prices I wouldn't care if the WHERE biased. /forums/images/graemlins/smile.gif
New/Unused Wolverine Quick Attach Trencher (A65583)
New/Unused...
1995 20 Ton Equipment Trailer (A65563)
1995 20 Ton...
(10) 6 Bar 20' Continuous Fence Panels (A66408)
(10) 6 Bar 20'...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
NEW HOLLAND 254 - 10' HAY TEDDER (A64277)
NEW HOLLAND 254 -...
Cattle Feeder (A65640)
