engine: yanmar vs shibaura
/ engine: yanmar vs shibaura #1
NHeuro
europe
NH tce 50 for the previeus see Bio
Simple what is the best mark yanmar or shibaura or +- the same
and what may i expect of the yanmar quality
thanks
/ engine: yanmar vs shibaura #2
Well, many John Deere's use Yanmar engines (have for years), and I don't hear of many engine failures, and our old 1990 Yanmar had a great engine in it. I also don't hear about the New Holland or Case machines having any engine problems. I think either engine would be a good choice.
/ engine: yanmar vs shibaura #3
I can't comment on the others, but Yanmar engines have been used in many sail boats over the years, as well as other industrial applications. And, in tractors, of course...
I can solidly attest for Yanmar.
However, I'd try an Internet search on Shibura...see what testimonials you find.
/ engine: yanmar vs shibaura #4
The engines are equal.
/ engine: yanmar vs shibaura #5
</font><font color="blue" class="small">( <font color="blue"> The engines are equal. </font> )</font>
Based on your experience maybe ?? I have always heard good things about Yamnar...never heard much about Shibaura at all....nothing bad sticks out in my mind about Shibaura...Like I say I honestly do not know much about Shibaura.....where are Shibaura made ??
/ engine: yanmar vs shibaura #6
I'm gonna venture a guess here.........
I think that was a politicly correct statement, both being equal quality..
I agree that I have never heard anything bad about either. However, I have heard ALOT of good about Yanmar, thats why I bought one. I think if the two are separated in the Gray forum and ask an opinion of each seperatly, you may get better feedback. The search idea on both is a good idea too.
Good luck.
/ engine: yanmar vs shibaura #7
The 3 cyl Yanmar on my 25 hp 1998 JD770 starts on the first crank, always. It is easy to service, at 402 hrs burns no oil whatsoever, runs clean and uses 1/2 - less than 3/4 gallons of fuel an hour. I'd buy another in a heartbeat. JD has used Yanmar engines for a LONG time. They must be reliable or the complaints would have moved them to a different supplier.
Having said that, I know nothing about Shibaura
/ engine: yanmar vs shibaura #8
Shibura has made Ford/NH CUTS for many years. Good machines with a great reputation. Just doesn't receive the attention that Yanmar does, possibly due to less aggressive marketing. I wouldn't be afraid of them...
/ engine: yanmar vs shibaura #9
I believe our Bobcat Trachoe has the shibaura in it. I would have to go out and look for sure but it is ten years old now and has been beaten pretty good and just keeps going. Personally I don't think one is better than the other, but both are great reliable engines.
murph
/ engine: yanmar vs shibaura #10
Shibaura may not be a household name, but I'm sure that you have heard some of these names: Perkins, New Holland, Case IH, and Caterpillar.
Shibaura has had a joint venture with Perkins for years. When Caterpillar purchased Perkins, Shibaura engines entered into the deal. Many smaller Caterpillar products are powered by Shibaura engines.
Fear no Shibaura or Yanmar.
/ engine: yanmar vs shibaura #11
</font><font color="blue" class="small">( <font color="blue"> Shibaura has had a joint venture with Perkins for years. When Caterpillar purchased Perkins, Shibaura engines entered into the deal. Many smaller Caterpillar products are powered by Shibaura engines. </font> )</font>
Thats an impressive line up. If Cat uses them they must be good engines.
/ engine: yanmar vs shibaura #12
I have had 2 new holland tc45d's for 5 years and never a problem with the engine.</font><font color="blue" class="small">( </font><font color="blueclass=small">( <font color="blue"> Shibaura has had a joint venture with Perkins for years. When Caterpillar purchased Perkins, Shibaura engines entered into the deal. Many smaller Caterpillar products are powered by Shibaura engines. </font> )</font>
Thats an impressive line up. If Cat uses them they must be good engines. )</font>
/ engine: yanmar vs shibaura #13
I have been importing both Shibaura and Yanmar for years. I have always preferred Shibaura for many reasons not just engines. With that said it is more important which model of each brand you’re referring to. They both build a super tractor and a crap tractor. I assume you are buying more than the engine and the engine is almost never the weak link on the import tractors so give me some model #'s to compare.
Buck
Unverferth Ripper Stripper (A64126)
Unverferth Ripper...
2023 WALLACE-THE ROOSTER ROOT PICKER PINTLE HITCH (A65054)
2023 WALLACE-THE...
2003 30ft Rinker Captiva Boat w 2017 30ft Tri-Axle HMDE Boat Trailer (A66738)
2003 30ft Rinker...
DEERE 544K Quick Attach Coupler (A68134)
DEERE 544K Quick...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A66738)
2021 Mercedes-Benz...
8ft Fork Extensions (A66734)
8ft Fork...
