engine won't start
/ engine won't start #1
mcbridek
Libby, MT
Yanmar
I have a tractor that will turn over but not start. Where do I start?
/ engine won't start #3
Gas or diesel?
Model and year?
/ engine won't start #4
What do you see when you crank it? White vapor coming out the exhaust is fuel that won't ignite. Nothing = fuel not reaching the cylinders.
What's your weather? below freezing, and the diesel has gelled? In that case you need to warm the garage, or replace the diesel in the fuel filter with room-temperature warmed fuel. You can buy fuel additives to reduce gelling.
You can test the Thermostart. (intake manifold heater) Twist the key left 10 seconds, then feel the manifold around the thermostart module (looks like a spark plug, with a fuel hose and an electric connection) to verify it is warming the manifold.
And on most Yanmars you can crank it with the compression released, then drop the release lever to let the inertia of the flywheel assist the starter.
Tell us what you see.
/ engine won't start #5
Welcome to the forum. :welcome: I would assume it is awfully cold in Montana this time of year. More details will help others to help you.
/ engine won't start #6
Make sure your battery is fully charged too. A weak battery will turn the engine over but not generate the compression needed for auto ignition. As mentioned, make use of the compression release too. If you have fuel, air and compression (ignition), it will start.
1996 International 4800 Bucket Truck, VIN # 1HTSEAAN6TH399113 (A65563)
1996 International...
2022 EZ-GO ELITE...
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
90in. Work Bench (A65640)
90in. Work Bench...
2012 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2012 CM TRAILER...
