Engine Speed for PTO Engagement
/ Engine Speed for PTO Engagement #1
STDBob
Upstate, NY
New Holland TN75
What engine speed is best to engage the PTO on a tractor?
/ Engine Speed for PTO Engagement #2
My manual says to do it at idle, and that's what I do.
/ Engine Speed for PTO Engagement #3
As low as possible seems the best RPM, that's what they told me when my B7510 was delivered and the experience I've had since hasn't made me change my mind.
When you engage the PTO it will be starting up something (say a rotary cutter) that isn't moving. The faster the engine the harder it's going to hit. It seems much better to start it going slow then rev the engine up after the PTO is engaged.
If someone knows of an implement where it's better to have the engine going at full speed when you engage I'd like to hear what it is - theres always more to learn!
John
/ Engine Speed for PTO Engagement #4
Idle speed is best. But some attachments take a lot of power to get running. If you have an attachment that tries to stall engine when PTO is engaged. Increase RPM's enough to not stall engine.
/ Engine Speed for PTO Engagement #5
20060114
On my Exmark zero turn mower (w/ 27 hp diesel), the instrs say pull the electric PTO engage at half speed. I find if I do it at lesser, the engine threatens to stall out, esp with the leaf catcher on.
With my tractors I usually try to have some kind of revs going, esp with the larger one (80 hp NH), and esp if the implement is heavy, say the discbine or even the sq baler. But generally it does OK with startup at fairly low revs. Or since that PTO is mechanically engaged I sometimes feather in the clutch to counter revs that are too low or too high, but I worry that I am shortening its life that way.
When I run it on 1000 RPM for my 7 ft 1287 Bush Hog, it seems more flexible prb because it is effectively downgeared with the higher PTO speed. Requires changing the tractor PTO shaft on mine since there is only one connection.
My BX-2200 Kubota seems to be pretty tolerant of how I engage its PTO, prob because it is working with lighter stuff.
What'dya think?
Jim
/ Engine Speed for PTO Engagement #6
If I try to engage at RPM speed, I throw the shear pin of my rotary cutter every time. So I got pretty good at changing it /forums/images/graemlins/grin.gif
Now I throttle down as far as possible and gently engage while crossing my fingers. So far, so good.
/ Engine Speed for PTO Engagement #7
I have always found it best to engage the PTO at the lowest RPM's possible. Sometimes this is not idle because at idle when engaged the engine stalls out. The best way I have found is to throttle down and engage then throttle back up.
/ Engine Speed for PTO Engagement #8
Your equipment will last longer if you engage and disengage at the lowest possible rpm.
/ Engine Speed for PTO Engagement #9
I work for a farm that uses a JD 336 baler, I was told to engage the PTO at 1500RPM's not exacly sure why, /forums/images/graemlins/confused.gif it seems like awfull rough start. /forums/images/graemlins/crazy.gif I guesss it's like ronjhall said it would probably stall the engine if the RPM's weren't high enough. /forums/images/graemlins/grin.gif
/ Engine Speed for PTO Engagement #10
</font><font color="blue" class="small">( I work for a farm that uses a JD 336 baler, I was told to engage the PTO at 1500RPM's not exacly sure why, /forums/images/graemlins/confused.gif it seems like awfull rough start. /forums/images/graemlins/crazy.gif I guesss it's like ronjhall said it would probably stall the engine if the RPM's weren't high enough. /forums/images/graemlins/grin.gif )</font>
Speaking as a motor vehicle service manager, there is no possible benefit to engagment of the pto at any speed above the minimum to keep the engine from staggering or stalling.
I would also point out that many PTO designs engage a shaft brake when the PTO is switched off so you also benefit from reduction of speed to idle before you disengage.
Lower engagement and disengagement speed = reduced shock loads on the system = longer life
/ Engine Speed for PTO Engagement #11
I have seen this discussed before, so I checked my owners manual. For my JD 5420 it says to throttle up to correct PTO speed 1700 rpm for 540E or 2400 rpm for standard 540 operation, and then to engage the PTO lever. I agree that engaging it at the lowest possible speed makes sense, but my book says do it differently. /forums/images/graemlins/confused.gif
/ Engine Speed for PTO Engagement #12
I'm sure you can engage the PTO at a higher RPM. It may take a more gradual slower release foot on the clutch to get it up to speed. I prefer to engage at a lower engine RPM then once fully engaged bring up the RPM to meet the required 540 of the implement.
/ Engine Speed for PTO Engagement #13
On machines such as headers, balers, mowers, etc the PTO should be engaged smoothly at the correct operating speed (540RPM) and kept at this speed. Engine speed should be kept constant on these and many other PTO
operated machines.
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2012 Mitsubishi Fuso FEC52S Cab and Chassis Truck, VIN # JL6AMG1A0CK003828 (A65563)
2012 Mitsubishi...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
New/Unused Landhonor Mini Rock Grapple (A65583)
New/Unused...
Stidham 2 Horse Trailer (A65640)
Stidham 2 Horse...
