engine side and front panel removal
/ engine side and front panel removal #1
Ken P
Bronze Member
North Granby, CT
Kubota B2410
Folks -
I feel dumb posting this, but I've got a new-to-me B2410 that I'm doing some service on, and I cannot figure out how to take off the front and side engine panels. The manual clearly states that you should pull sideways from the top of the panels, then lift off. It has a little diagram indicating this, too.
None of the panels on mine can be pulled in that manner. The front panel can be pulled out somewhat from the bottom, but then no further. The side panels lift up slightly, but no further, and cannot be pulled off outwards.
I'd be appreciative of assistance, and stand ready to give myself a serious "doh!" whack on the head. Thanks -
Ken
Never mind...figured it out. There are some spring clips that needed to be fiddled with. Squeezed them, lifted a bit and then the panels could be pulled off.
Ken
/ engine side and front panel removal #3
With the new B series its a bit different, you loosen a couple of screw downs and the front grill flops forward, then the side panels just lift off,,,,,pretty cool design
/ engine side and front panel removal #4
Ken
Don't think you need to squeeze the clips, just give a tug and the arrowhead pops out of the clip. I've got a B2710, assume it's the same. It takes a pretty good tug, feels like you're going to break something the first time, but then you get the feel.
KUBOTA KX033-4 EXCAVATOR (A64279)
KUBOTA KX033-4...
2010 New Holland T8020 (A64126)
2010 New Holland...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
2015 Ford F-550 Utility/ Plumbing Truck, VIN # 1FDUF5GYXFED42880 (A65563)
2015 Ford F-550...
2011 BRENNER TANK TRAILER (A65643)
2011 BRENNER TANK...
Lot 602 (A62613)
Lot 602 (A62613)
