Engine seized???
/ Engine seized???
You can also bump the engine over with a geared transmission and a dry clutch,
by simply putting the tractor in it's highest gear and rocking the whole machine back and forth.
With a front mounted hydraulic pump your options are a bit limited.
A large pry bar to the flywheel teeth or rock the tractor.
Or you can try to rotate it by engaging the pto and turning the shaft but thats only 5 to 1 or so ratio.
Pulling the glow plugs or injectors will remove the compression so it should turn over easily.
Thanks - unfortunately the bucket is dropped so I can't really get it to budge much on my own. I will see what I can do though. That may be an option.
/ Engine seized??? #22
Maybe you could get a jack under the bucket to lift it then block the cylinders or they might even hold with the valve.
/ Engine seized??? #23
I don't know how the front of yours is configured to the pump.
I have an industrial backhoe. I have a shaft out the front of engine that goes to my pump which is in the nose of the machine.
ON THAT SHAFT, is a universal joint. I don't know about yours, but in my case, I'd feel comfortable applying some pressure via that joint (with a rod type item) to get some twist on the crank.
I wouldn't put excessive pressure on that but for the sake of moving or adjusting engine position, it might be a contact point that you might be able to use (?)
/ Engine seized??? #24
Jack up the bucket enough that you can get a post or something to lay under it so it will slide easier,
pull the glow plugs out AFTER you blow around them so that dirt doesn't fall in the hole,
put the tranny in the highest gear available and rock the tractor back and forth with the rear tire. Maybe even have someone on the other tire too.
Report back here with your findings.
/ Engine seized???
Ended up having it winched onto a flatbed to my mechanic - I don't have what I need to do the labor on it right now! I'll report back on what they find out.
/ Engine seized??? #26
Another thing you could do is loosen the belts. I've seen alternators that have rusted and will not allow the engine to turn over. If it was sitting for a short period it's not too likely but you never know. You could also remove the hydraulic pump from the front of the engine. They are designed to come off so a belt can be replaced.
/ Engine seized??? #27
Go ahead and force the engine over and bend a piston rod while you're at it. I would never crank one without an air cleaner. It don't take but two weeks for lock up if water gets in.
/ Engine seized??? #28
I’d pull all the glow plugs and try spinning it again with the starter. A breaker bar on the crankshaft would be a better option but the starter isn’t going to hurt anything that’s not already hurt. If that doesn’t work I’d narrow down the possibility’s further by removing the fan/alternator belt and see if if it’ll turn over. If it still doesn’t turn try removing the hydraulic pump. Before you get into all of that are you sure that the battery is good?
/ Engine seized??? #29
I'd still recommend pulling the injectors; or, perhaps better yet, pull the glow plugs (you already have a bad one that needs pulling anyway).
Be real careful about using force. Rarely does force end up producing good results in things such as this.
One possible scenario is that it's hydrolocked. Maybe leaking injectors?
I agree with pulling the injectors. I would also recommend a small diameter borescope/camera. Push the borescope through the injector port, and look for anything inside of each cylinder. If the borescope you get has taking pictures ability (there are some that attach to phones available and screen shots should be an option if no other) then post photos on this forum.
If you have not yet, put in the air filter or otherwise block that passage!
/ Engine seized???
Update:
Seems that something has seized internally - they pulled the hydraulic pump up front and still aren't getting anything to turn over. May need to be rebuilt or replaced as a result... Seems like the worst case scenario... Went from running fine to completely seized up. Really unfortunate☹️
/ Engine seized??? #32
Please keep us updated, even if it is a total rebuild as this really is an educational site.
Very good part vendors for our tractors here also.
Good luck.
/ Engine seized???
Good luck.
Thank you - can you or anyone else on here give me an idea of what would be a reasonable cost for a rebuild / complete replacement? At this point I'm worried about shelling out more cash.
/ Engine seized??? #34
No, I can't, but I have had GREAT luck and advice with Affordable listed below. Give them a call.
Jinma Dealers Who Support TBN:
Affordable Tractor Sales Co. LLC
6972 Highway 36 North
Bellville, TX 77418
Phone: (979) 865-4002
Fax: (979) 865-5183
Website: Home of compact Jinma, Foton, and Koyker Tractors and Parts, Wood Chippers, Backhoes - Affordable Tractor Sales Company
Description: We are a full service Jinma Tractor dealership with one of the largest Jinma replacement parts supplies in the USA. We also sell Jinma wood chippers & parts. We are a Koyker distributor for front-end loaders and backhoes. We are located in Bellville, Texas approximately 75 miles NW of Houston, and 75 miles SE of Austin. Full service dept, monthly specials, extended warranties and zero down Financing (WAC). Shipping services all across the USA. We look forward to hearing from you!
Circle G Tractor Sales, Inc.
842 Hwy 72
Lamar, MS 38642
Phone: (662) 252-5272
Website: Jinma Tractors, Jinma Tractor Dealers, Wood Chipper Dealers
We are the largest Jinma parts dealer in the USA. We have an extensive online parts store at Jinma Tractor Parts, Farm Pro Tractor Parts, Farmpro, Nortrack, Agracat where you can order online or give us a call. We also carry parts for the Farm Pro, Agricat, Workhorse, Foton, Jinma Wood chippers and many other Chinese made tractors and wood chippers. We are a full service dealer for Jinma Tractors. We carry lines such as Ferris zero turn mowers, Hustler, LITW Backhoes, Koyker Front end loaders, Jinma Front end Loaders, Jinma wood chippers, Chinese Yachai bulldozers, Big Bee, Atlas, Tarter, Powerline, Tonutti and others. We offer a full line of trailers and package deals. We ship ationwide. When you're in the market for your next piece of equipment give us call and we will do our best to earn your business.
Keno Tractors
15555 Highway 66
Keno, OR 97627
Phone: (866) 363-8193
Website: http://www.kenotractors.com
Large selection of new Jinma tractors. Also carries Mahindra and used equipment.
/ Engine seized???
Bellville, TX 77418
Fax: (979) 865-5183
842 Hwy 72
Lamar, MS 38642
Keno Tractors
15555 Highway 66
Keno, OR 97627
Thank you for the reference!
/ Engine seized??? #36
I'd have them pull the head before splitting and pulling the engine.
/ Engine seized??? #37
Hi all,
Jinma 284 owner!
Unfortunately I don't have a ton of knowledge of the history of this tractor, as I just purchased it a couple months ago. I also don't have a ton of mechanical knowledge or understanding, so bear that in mind as well. To start, the tractor was running fine upon purchase - though there was no air filter at all, and I'm concerned that might be contributing to what's now happening. I was gone for a month and upon return, I went to fire things up. The tractor turned over and emitted a good amount of black smoke, but didn't engage. I attempted to turn it over again and it struggled on the second try. Attempted again and it just made a "clunk" sound, which I assume is the starter hitting the flywheel and struggling to move it. I took the starter off and tested it in isolation. It ran fine. I tried to move the flywheel through the gap where the starter normally seats, and was unable to budge it with a crowbar in the teeth. The fan up front moves but won't move the timing belt. The generator fan moves but won't move the timing belt. The timing belt is seized up and I can't move it at all with all my strength. I've read about people using something to try to move the crankshaft but I'm not sure where people are tying onto that - all I can see is it connects up to the hydraulic pump up front, and can't see anywhere that I'd be able to get anything onto it for leverage.
Honestly, I don't understand how the engine seized up when it's been running as recently as a month ago. I pulled the oil dipstick and there's nothing out of the ordinary - no signs of water, etc. Two out of three glow plugs show resistance. Could the third one not firing up be enough to keep things from turning over? It was quite warm - in the 70s - when I made these attempts.
I had just purchased an air breather assembly and was about to install it, but now I can't even get the tractor to start, and I have no idea where to go from here.
Any help would be greatly appreciated!
Right off the bat, I would suspect you ingested something via the air intake...bird or bird nest, rat..... I like the idea of removing injectors and see if things move. If you had a borescope....Harbor Freight carries them for a great price.....stick it in the injector hole and have a look around.....checking for any fluid (water) accumulation. Also stick it in the ai intake and have a look around.
Get some help and push in the clutch while trying to turn the engine. Seems you have disconnected anything else that could be seized that would prevent the engine from turning over.
Carefully remove the drain plug and inspect the initial drippings/outflow from the crankcase checking for water exiting first. What condition is the oil that comes out?
Do that and check back to go from there based on results.
/ Engine seized???
UPDATE:
Strangely, we've gotten it started up just fine, after a strange series of events. Long story short - I towed it to my regular mechanic, who pulled off the hydraulic pump off the front of the crankshaft and attempted to turn it over by hand on the front crank. No luck. Not sure of what other, if any, attempts he made to get things started (they've been swamped with work right now). So, I had the original seller pick it up and have a look at it to see what he thought. He couldn't really make sense of why it would be locked up so wanted to get his hands on it.
He pulled the starter and apparently was able to crank on it on the flywheel to get it to turn. Claimed that the battery was toasted (not my experience) and guessed it wasn't getting enough juice to the starter. Put power onto the battery and got everything started just fine.
In the end, I don't really have any answers - other than it's running now, thankfully!
I think I'm going to get ahold of a new starter, because even when looking it over upon purchase it sounded weak upon start.
Thanks y'all for your assistance with this!
/ Engine seized???
UPDATE:
For all I know the damn kill lever was probably engaged :geek::geek::geek:
/ Engine seized??? #40
I saw some boys here had a Ford pinto locked engine. Finally put a 3' pipe wrench on crank and an 8' pipe over the handle. Ran a chain from end of pipe to a truck bumper and took off. Drove that car around here for years after that.
