Engine problems.
/ Engine problems. #1
winton
I've got a Case 310 (~1957) that has run and been cared for pretty well for many years. It currently runs very smoothly, but only for about 30 minutes, at which point it revs a few times and then konks out altogether. Attempts to restart it result in it running for a few seconds before it dies again. Letting it cool down for a few hours means I can run it for another 30 minutes or so before it dies.
Ignition system seems fine -- getting healthy sparks in all the right places. There seems to be compression, otherwise it wouldn't run at all. Carb was cleaned not too long ago.
Any suggestions?
Thanks.
/ Engine problems. #2
You have some kind of fuel flow problem.
/ Engine problems. #3
If the fuel flow is gravity fed, check the vent on the gas tank or gas cap whichever it has. It sounds like you are pulling a vacuum in the tank and running out of fuel. After you let it sit for a while, the vacuum equals out and fuel flows again.
This only applies if it is gravity fed, if it has an electric pump, the pump could be getting hot and shutting down. If it has a mechanical pump, you could be getting vapor lock meaning that the fuel line is getting hot and vaporizing the fuel in the line and since the the pump will not pump air it the fuel has to cool down and return to liquid to flow again.
Hope this helps
Leroy
/ Engine problems.
Good suggestions. There's no fuel pump, and since I've taken the gas cap off a few times during the period when it won't start (to make sure I wasn't being stupid and hadn't just run out of gas) that should eliminate any vaccuum problem, right?
/ Engine problems. #5
winton,
I am guessing that this is a gas tractor. If it is, try a new condenser.
/ Engine problems. #6
I'll go with an electrical problem too. Runs long enough to heat up and then requires cool down before starting.
I had a Briggs& Stratton 8 HP that used to do the same thing. It was a condensor as someone else has stated.
Egon
/ Engine problems. #7
I had a '57 Ford automobile that behaved similarly. It would crank cold and run until warm and die. Someone told me to replace the coil and that fixed the problem. That was the only time I ever saw the problem, so it must be rare.
/ Engine problems. #8
Winton,
Taking the gas cap off would eliminate the vacuum problem. The surging a couple of times before it quits is a symptom of fuel flow problems. I am really not familiar with the fuel setup on your tractor, we had 9N Fords and a TO30 Ferguson. Does the tractor have a fuel filter/water separator with a clear bowl so you can see if gas is flowing? If so have you changed the fuel filter or cleaned the inlet screen on the filter/separator?
/ Engine problems. #10
I agree.. sounds like a fuel delivery problem.. it is starving and leaning out.. gov kick it up a couple times then dies.. carb bowl being empty.. restarts in a few minutes and quickly starves again as it sucks carb bowl empty.. let set.. and carb and fuel line recharge.. and runs again as before.
Even if the carb is clean.. there may be an upsstream blockage.. or even vacume on the tank from a clogged tank vent..
Soundguy
/ Engine problems. #11
winton, I vote fuel flow problem ,Just last week my neighbors massey 50 (gas) was very similar to your symptom where it would start and run for about ten minute the sputter out, checked and cleaned bowl ,blew out line to carb,same thing would only run ten minutes, Had to go other direction from bowl thru shut off to tank where sediment was blocking fuel from entering line to bowl..If its a kept outside tractor the condensation that helps form a light corrosion on the inside of tank finally takes its toll when enough of it covers the screen leaving the fuel tank,just lets enough gas through to supply it for a while...Well at least that's what I found on my neighbors tractor ...Good luck ,Mark S. /forums/images/graemlins/smirk.gif
/ Engine problems. #12
Any verdict yet on the problem winton? Hope it's resolved by now!
/ Engine problems. #13
</font><font color="blue" class="small">( at which point it revs a few times and then konks out altogether. )</font>
I had the misfortune of running out of fuel this past weekend on my diesel. Increased revs were the first indication of a problem. I'll cast a vote for a fuel delivery problem.
TBAR
/ Engine problems. #14
I had the same symptoms with an M Farmall. Turns out there was a large piece of rust blocking the fuel line from the tank to the sediment bowl.
/ Engine problems. #15
I had this type of problem on a Super C because the rubber fuel hose was too long and looped under the air breather assembly. Rerouted the line as short as possible and had no more problems.
/ Engine problems.
Thanks, everyone. I replaced the sediment bowl filter and fuel line, and all seems well, now. (Sorry for the delay in updating you -- it took me this long to get the parts!)
(2) UNUSED 15X19.5 TIRES W/6 LUG RIMS (A62130)
(2) UNUSED 15X19.5...
2020 KUBOTA SVL75-2 SKID STEER (A62129)
2020 KUBOTA...
4 Shelf Rolling Cart 6ft x 3ft (A61165)
4 Shelf Rolling...
Bull Skull (A61569)
Bull Skull (A61569)
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A59228)
Dvorak Model 3072A...
2017 Ford F-250 Pickup Truck (A61568)
2017 Ford F-250...
