IH3444
Elite Member
- Joined
- Jan 10, 2004
- Messages
- 2,648
The reality show could be called.
The Man I Wish Was My Brother
lol, those ARE my clean clothes!
No really, it's always so dirty and greasy even clean clothes would look like that in about 5 minutes.
I'm leaning more and more towards leaving the pistons in and not balancing them.
Of course I still don't have the bottom end opened up yet. I hope I haven't let anybody down if I make that decision. But man, there is a lot of work removing just that front timing gear cover and housing. I'm not looking forward to remove the head at all. I'm still confident that the scoring on the old crank journal is the reason for loss of oil pressure. That's why I'm replacing it. Now, with a new pump and crank and new bearings, the bottom end should be good.
Leaving for work today, so I won't be posting until Wednesday.
See you guys later.
Thanks Cyril,
I appreciate that.
Before I leave today, I will try to get the bottom off. I'm leaving the oil pan on since all the bolts holding the engine and what they call "main oil housing" are separate from the pan. I need to get that off to get to the journal caps. But like I said, I will look at if it is possible to remove the pistons safely without damage. But more important, that I can install them safely. If I don't feel confident about it, then I'll leave them in.
Curious as why you didn't use the original timing marks ?the first thing I did was mark all the gears that would be coming off.
After taking the cover off, the first thing I did was mark all the gears that would be coming off.
Maybe you can see the markings in the close ups? That way, I can line up the meshing teeth exactly the same as when they came off.
Regarding the timing marks:
I saw the lettering on all 4 gears. I rotated the crank a few times and the large gears are exactly twice the diametrical pitch as the small crank gear...so their relationship will never change. However, If you look (or if you can see it) the Idler gear was not placed correctly. That is, the corresponding AA and DD on the Idler gear did not line up to AA and DD on the fuel injector pump and cam shaft gear.
Not wanting to disrupt the gearing, I marked tooth for tooth as a precaution.
What I plan to do then, is set all the gears exactly as I marked them. Then if I want, I can remove the Idler gear and set the respective markings ... line them up to the fuel injector pump and cam gears using the AA and DD like they are supposed to be. But when you think about it, all that idler gear does is transmit rotation to the other gears from the crank gear. Being 2:1 , their respective alignment would remain constant. So in fact, it doesn't matter how the idler gear is installed, as long as the crankshaft, injector pump and cam shaft gear are in the correct position relative to each other. And I think that is exactly what they did on this engine.
Does that make sense now?
I agree with not balancing the rods, or pistons. Just get her back together. I would like you to inspect the old oil pump for wear.
Yeah, I found out the journal cast webs in the block in fact do prevent me from removing the pistons out from the bottom. So the head is remaining on and I will not balance the pistons and rods after all. (Save that for another day) I'll post photos of that when I get home.
Also, I posted a photo earlier of the new oil pump I bought. I got it to make sure that was not going to be a problem in the future. I figured it was cheap insurance.
I agree that marking the gears like I did can't hurt.
The biggest thing at this point should be just remembering to put pieces of rubber hoses over the bolts for the rod caps. I forgot to do that once and damaged my crank. Granted you have a new one, but it can't hurt to get them on early so you dont forget to do it before putting the crank in.
Rob, a lot of rods have studs mounted in the rods and the cap then fits on the end, then secures with nuts. But since you have bolts that thread into the rod, you do not need to worry about this problem.
1st oil and then wipe off the gasket. Then....A thin patina of rtv silicone rubber on one slde and grease or nothing on the other. If you ever take it apart again the silicone will release cleanly leaving the gasket stuck intact on the other side. Reapply rtv for reuse.What kind of gasket sealer should I use for between the main oil sump and engine, and the timing gear cover and housing?
The Shellac type or that sticky stuff?
Rob-
