Engine Oil?
   / Engine Oil? #1
bama21fs
jacksonville, alabama
john deere 1025R
I am going to be changing the engine oil in my John Deere 1025R and I was thinking of using Shell Rotellaョ T6 Full Synthetic Heavy Duty Engine Oil. Thoughts?
   / Engine Oil? #2
T6 is a good choice. Is your tractor still under warranty? If so check to make sure it meets the specs. Most likely it does.
Welcome to TBN.
   / Engine Oil? #4
Yep, SOPUS (Rotella, Pennzoil, Quaker State) makes a great synthetic. Should work great for you. I don't use it, but there are so many great oils in the market place. T6 is a solid performer. Only choice is to get the viscosity grade you meets your needs.
   / Engine Oil? #6
I have run T6 .. Good product
   / Engine Oil? #7
agree with above responses. been using T6 in tractor after initial break in, now 500 hrs. also use it in everything i have (4stroke) from small to large.
   / Engine Oil? #8
Wally world sells it for a good price. I called Cummins when I got my 6530C with the Cumming B 3.3 NA engine. I was using it in my other stock and liked it. Their reply was that it "would love for me to use Rot. T 5w-40". So I have.
   / Engine Oil? #9
I use T6. After years of oil sampling in my big trucks, I'm sold on Shell Rotella products.
   / Engine Oil? #10
Been using Rotella T-6 for 3 plus years in my Yanmar with great results. Remember to use a quality filter too.
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
UNUSED HURRICANE STAND ON SKID STEER (A51247)
UNUSED HURRICANE...
2019 CATERPILLAR 330GC LONG REACH EXCAVATOR (A51246)
2019 CATERPILLAR...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
(APPROX 24) 2" X 6" X 60" CHANNEL IRON (A51247)
(APPROX 24) 2" X...
