Engine Oil?
   / Engine Oil? #1
bama21fs
jacksonville, alabama
john deere 1025R
I am going to be changing the engine oil in my John Deere 1025R and I was thinking of using Shell Rotellaョ T6 Full Synthetic Heavy Duty Engine Oil. Thoughts?
   / Engine Oil? #2
T6 is a good choice. Is your tractor still under warranty? If so check to make sure it meets the specs. Most likely it does.
Welcome to TBN.
   / Engine Oil? #4
Yep, SOPUS (Rotella, Pennzoil, Quaker State) makes a great synthetic. Should work great for you. I don't use it, but there are so many great oils in the market place. T6 is a solid performer. Only choice is to get the viscosity grade you meets your needs.
   / Engine Oil? #6
I have run T6 .. Good product
   / Engine Oil? #7
agree with above responses. been using T6 in tractor after initial break in, now 500 hrs. also use it in everything i have (4stroke) from small to large.
   / Engine Oil? #8
Wally world sells it for a good price. I called Cummins when I got my 6530C with the Cumming B 3.3 NA engine. I was using it in my other stock and liked it. Their reply was that it "would love for me to use Rot. T 5w-40". So I have.
   / Engine Oil? #9
I use T6. After years of oil sampling in my big trucks, I'm sold on Shell Rotella products.
   / Engine Oil? #10
Been using Rotella T-6 for 3 plus years in my Yanmar with great results. Remember to use a quality filter too.
2014 DITCH WITCH RT45 RIDE ON TRENCHER (A51246)
2014 DITCH WITCH...
(2) 300 GALLON POLY TOTE (A51248)
(2) 300 GALLON...
7022 (A50322)
7022 (A50322)
2025 Star EV Capella 2+2 Electric Golf Cart (A51694)
2025 Star EV...
(2) UNUSED 3500# BRAKE AXLES (A51247)
(2) UNUSED 3500#...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
