Engine Oil Leak
/ Engine Oil Leak #21
Shutting down at half throttle has worked well for me too, as you stated just a little run on... no big deal /forums/images/graemlins/shocked.gif
/ Engine Oil Leak #22
<font color="red"> Somehow I bet that these are all clues as to why the back firing problem exists.
</font>
I would suspect a timing problem based on the symptoms you describe.
/ Engine Oil Leak #23
How so? Then everyone's got a timing problem! The engine runs fine. The Kohler on my old tractor used to backfire on shutdown with a much more pronounced bang if you didn't shutdown at 3/4 throttle. It's just unburnt fuel in the exhaust thanks to the ignition coil being shut off before the engine has stopped sucking fuel.
I don't find this a big deal. Sometimes it does this, other times it doesn't. I bet if you removed the exhaust pipe from the engine block it would never do it. The PT exhaust (in recent model 422/425's) has two 90 degree angles. I bet that increases back pressure quite nicely. If we could turn the engine 90 degrees or even 180 degrees counter clockwise we could eliminate one or two of those bends. Rounded corners would help. Perhaps custom headers are needed. /forums/images/graemlins/grin.gif
/ Engine Oil Leak #24
I have NEVER noticed the exhaust so hot that it glowed red. I'll start looking specifically for that, but I think I'd have noticed if had been getting that hot. You might want to mention it to PT and see if they all do that now.
Phil
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
2012 Peterbilt 337 G and H 8000 Container Handler Truck (A64194)
2012 Peterbilt 337...
Lincoln Shield-Arc SAE-400 Engine Driven Welder (A63689)
Lincoln Shield-Arc...
2015 ISUZU NQR 4X2 DEBRIS TRUCK (A59911)
2015 ISUZU NQR 4X2...
APPROX. 2000 GALLON FUEL TANK (A63291)
APPROX. 2000...
Harlo HP6500 (A60462)
