Engine Oil Leak
/ Engine Oil Leak #21
Shutting down at half throttle has worked well for me too, as you stated just a little run on... no big deal /forums/images/graemlins/shocked.gif
/ Engine Oil Leak #22
<font color="red"> Somehow I bet that these are all clues as to why the back firing problem exists.
</font>
I would suspect a timing problem based on the symptoms you describe.
/ Engine Oil Leak #23
How so? Then everyone's got a timing problem! The engine runs fine. The Kohler on my old tractor used to backfire on shutdown with a much more pronounced bang if you didn't shutdown at 3/4 throttle. It's just unburnt fuel in the exhaust thanks to the ignition coil being shut off before the engine has stopped sucking fuel.
I don't find this a big deal. Sometimes it does this, other times it doesn't. I bet if you removed the exhaust pipe from the engine block it would never do it. The PT exhaust (in recent model 422/425's) has two 90 degree angles. I bet that increases back pressure quite nicely. If we could turn the engine 90 degrees or even 180 degrees counter clockwise we could eliminate one or two of those bends. Rounded corners would help. Perhaps custom headers are needed. /forums/images/graemlins/grin.gif
/ Engine Oil Leak #24
I have NEVER noticed the exhaust so hot that it glowed red. I'll start looking specifically for that, but I think I'd have noticed if had been getting that hot. You might want to mention it to PT and see if they all do that now.
Phil
2008 Ford Expedition SUV (A61574)
2008 Ford...
2014 Nissan Frontier Ext Cab Pickup Truck (A61573)
2014 Nissan...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
14in Digging Tooth Bucket Excavator Attachment (A64194)
14in Digging Tooth...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
FRONT MOUNT BLADE W/ MOUNTS (A63291)
FRONT MOUNT BLADE...
