engine oil filter for tc40
   / engine oil filter for tc40 #1
greenthumb
SE/Mid Michigan
tc40, exmark lazer Z
I picked up a new engine oil filter for the next oil change and when I looked at the one on the tractor it is much larger than the one they gave me at the dealer. the new new holland one has stamped on it the numbers 87415600 is this one right or do I need to go back and exchange it.
   / engine oil filter for tc40 #3
I just bought two of those tiny filters. They are just barely bigger in diameter than the gasket. I don't know if they are adequate, but I'm thinking of looking to some other supplier like Fleetguard. I just can't see paying NH's high price of around $9 for that tiny little filter. It appears to me that the filter is just over half the size of the previous filter. The original filter that came on the tractor was even bigger (as I remember). /forums/images/graemlins/smirk.gif
the old filter is much bigger. this is only the third oil change for the tractor so I am not used to seeing the filter. when I looked at it seemed small and than compared to the one on which I believe is the same size as the original there is a very noticible size differnce. I wonder if the smaller size will protect the engine the same as the original one. I don't ever remember any of my car oil filters changing sizes after a few years. Funny thing is this small new one cost more than the bigger older ones.
   / engine oil filter for tc40 #5
you might take a look at napa's 1452, i think everything is the same but more than twice as big. its used on other model NH diesels.........
   / engine oil filter for tc40 #6
I didn't look into it, but I bought a filter for my 2120 a year ago and it was one of the small ones. I questioned it and the clerk said that was what they changed too. Since then however, I've gotten the larger ones I used to get. I didn't ask what was up. Maybe the bigger ones are still availabe or the dealer had some to use up. I'm getting due again so I'll check the numbers.
   / engine oil filter for tc40 #7
The larger size filter will not fit on my 2000 TC35D due to the FEL frame mount and hardware.. a bolt head prevents the larger filter from fitting. I had to go back to dealer to return the larger for a smaller(years ago).. the smaller filter even cost more.
   / engine oil filter for tc40 #8
I know many will look on this suggestion with suspicion, and I don't mean to start a discussion on it's acceptability, but I've used the Motorcraft FL-300 (and cross-referenced filters from Purolator and AC) on my 1720 and TC40D for almost 20 years now. It's equivalent in flow (superiorior actually), size, relief pressure, seal diameter, threads and construction to the larger NH filter.
   / engine oil filter for tc40 #9
</font><font color="blue" class="small">( I know many will look on this suggestion with suspicion,... )</font>
Suspicion?... Not me! /forums/images/graemlins/cool.gif Thanks for the info, Duane. /forums/images/graemlins/smile.gif
   / engine oil filter for tc40 #10
The Motorcraft FL-300 oil filter is the equivalent to the larger NH filter?
Thanks for the tip, I'm writing this filter number down for future reference. /forums/images/graemlins/grin.gif
2020 EZ-GO EXPRESS S4 GOLF CART (A51247)
2020 EZ-GO EXPRESS...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A53426)
2019 FREIGHTLINER...
Ford Super Duty Pickup Truck Bed (A51692)
Ford Super Duty...
John Deere 772-A Grader (A52384)
John Deere 772-A...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A53473)
2022 MAXXD BD14...
2017 DRAGON 130 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 DRAGON 130...
