engine oil filter change for b2710
   / engine oil filter change for b2710 #1
NewB
Kubota B2710
Need to change oil filter @ 100 hours on 1999 B2710. How to remove left side engine cover for clear access to oil filter? Appears to be attached with some sort of v clips. Use angle needlenose pliers to squeeze clip together & pull up or ??
   / engine oil filter change for b2710 #2
Hi NewB,
Just grab ahold of it with both hands at the top close to the clips and give it a sharp tug towards you/away from the engine. It should pop loose. Mine were kind of sticky so I adjusted the clips and lubed them with lithium grease, now they don't give me any more trouble.
If you can't get it loose with a tug, you can squeeze/spread the clips while you pry with a big screwdriver.
Good Luck
Thanks so much for your reply - Just a little grease, then a tug and the panel came right off - seemed too simple. Had already changed transmission fluid & filter, so now I can complete the 100 Hrs maintenance with the oil filter change.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
KJ 42'x30' Metal Storage Shed (A50121)
KJ 42'x30' Metal...
2013 Infiniti JX35 AWD SUV (A50324)
2013 Infiniti JX35...
