Engine oil and filter once a year?
   / Engine oil and filter once a year? #31
Wayne County Hose said:
I never said I know more than service managers. I would take the opinion of the people that designed the equipment rather than a guy sitting behind the desk at Pigsknuckle Tractor Repair.
99% of the time the people that "designed" equipment ARE NOT the people that write the manuals for it and THOSE are the persons that not only cant speak English...they dont know "hog jowls from horse manure" about most things! My own manual states oils used have to be one of three different API catgaorys ...TWO of wich are totally OBSOLETE and the thirst one is a catagory that was introduced in 1994. AT LEAST they could get with "the program".
I am the one that stated that you knew so much more than any service manager..since you so blatently stated they didnt know their left foot from the elbow.
   / Engine oil and filter once a year? #32
Having worked for, at my last count, at least a dozen service managers, I can tell you that I have never seen the most knowledgable mechanic chosen to lead the service department. Not that the most knowledgable mechanic makes the best service manager, but the guy chosen usually is not even a good mechanic. We used to all shake our head and wonder how that idiot got the job. Then we find out why, they're usually the best "yes" man. While I am sure there are some very fine service managers out there, my experience has shown me that it's the biggest b.s.'er that gets the job.
I remember bringing a Chevy service van back to the dealer for a leaky pinion seal. When the service manager was told it had a leaky pinion seal in the rear, he asked "which side?" My co-worker looks dead at me and says, "we're fd." It was hysterical.
   / Engine oil and filter once a year? #33
I use my tractor year 'round so it never really "sits" all Winter.
I use it slightly less in the Winter though. I change oils and filters every Spring since the Summers are very hot. I feel better about having fresh oil during those severe hot months, perhaps offering better protection when I need it most? However, I don't really know if this is correct or not, but that's why I do it. I too use Mobil 1 synthetic.
   / Engine oil and filter once a year? #34
Not sure if fall or spring time changes are even part of the whole equation?? But lets make an assumption here if I may.
You do a full service next spring; next day you fall and break a leg ( lets hope not of course) and the full rest of the year you CANT operate your tractor AT ALL ! Maybe?..Xmas week of 2008 you need to run it for 1 hour to clean the drive of snow (???) Does that mean in the spring of 2009 you do a full oil and filter change AGAIN?
YOU know how its been worked over the years...how its been serviced yearly..etc..etc...so do you dump the oil and pitch the filter with 1 full hours time on it
( see what Im getting at?)
   / Engine oil and filter once a year? #35
Stating that ANY vehicle ( here we speak of tractors of course) HAS TO HAVE the engine oil and filter changed every 12 calendar months is akin to saying that IF your "200 hour service" is done at 210 hrs...225 hrs..etc...the rig is going to blow up or something. Oh..and make sure you fully grease your FEL every "10 hours of work"...because if you run over to 11 or 12 hours..it will fall completely off!....:eek:
   / Engine oil and filter once a year? #36
........if the beagle didn't stop to take a dump, he would have caught the rabbit.
   / Engine oil and filter once a year? #37
a service manager is more of a salesman than a technician, hence the lack of knowledge isn't necessarily a handicap when a person is in that position.
I'd venture that the qualities that make a good mechanic aren't the same as the qualities that cause one to be able to deal with people.
But I wouldn't go to a service manager for advice, other than basic info, they dont deal with the ins and outs of the vehicle, just the customers.
   / Engine oil and filter once a year? #38
Sully, I see what you mean.
My example is based on what I've been doing, and so far I've managed to get a couple hundred hours a year on the tractor using it year round. Like I said, I'm not sure if what I do is correct, but it makes sense to me. The other reason for a Spring change is that's when I get a week up at the property ... enough time to do it all during Easter vacation.
But if I only had 1 hour on the oil then ... hmmmm? I also wonder when I move up there full time if that will change?
   / Engine oil and filter once a year? #39
NOW ya see what Im talking about...:D. IF my oil changes were every..say 200 hrs. And I got say 100 hrs on it each year...YES I'd do an oil change. I mean..geeze..pull the pan plug..let it drain even overnight as I do something else...put the plug back in and fresh oil...No biggie at all.
I have a HUGE walk behind roto-tiller here..that I bought 23 years ago. Used it hard for a few years and then I did a full service on it one fall...everything..and it SAT...in the basement... for 19 years! This summer I pushed it out of the basement...added gas with Tecron carb cleaner to the fuel and pulled the starter till I thought Id flat die!! When it finally did fire up ( just prior to my heart attack...lol) a friend and I used it A LOT this summer doing final tilling of the back yard prior to planting grass seed and also for raised flower beds. It got an oil change ( no filter on it) right before it went into hibernation for this winter. Next year I will again use it for front yard flower beds.
But bottom line is ...if the way you service it makes sense to you...THATS all that matters!!
   / Engine oil and filter once a year? #40
Follow on question, that has been danced around a bunch (and I think Sully answered his thoughts exactly)
Lets say you are on the "change once a year" schedule.
Speaking in Generalities, you use your tractor more in the summer than in the winter.
Is it better to change it in the spring when taking the machine out of hibrenation so to speak, where there was more chance, time etc for the water to accumulate in the oil, or is it better to do it in the fall after the completion of the most work, so it has relatively "clean" oil to sit through the winter with?
Can anyone reference something other then gut feelings would be the follow on.
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2010 John Deere 8320R Tractor (A59814)
2010 John Deere...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56438)
2014 Doyle Dry...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60460)
2019 Ford F-550...
