Engine not shutting down
   / Engine not shutting down
Thank you all for your input.
It is not possible to right now to find the problem because it is currently working. There is an engine stop knob that I assume closes the intake off. But I have not tried it when the problem happens. I will next time I think of it when it don't shutdown.
Does anyone have any links to wiring diagrams?
   / Engine not shutting down #12
The engine stop knob does not close off the intake, it operates the same lever as the fuel shut-off solenoid to shut the fuel off at the injection pump.
   / Engine not shutting down #13
I had the same problem but noticed the key fell out of the ignition switch.:)
I know your problem is more involved but I'd look at the switch. I had some weird starting issues and when the key started to fall out I replaced the switch. Problem solved.....I think.
   / Engine not shutting down #14
Had this issue. Check the 10 amp timer relay fuse.
2014 Club Car Carryall 295 4x4 Utility Cart (A59228)
2014 Club Car...
2022 FREIGHTLINER CASCADIA SLEEPER (A56129)
2022 FREIGHTLINER...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
VOLVO EC460CL EXCAVATOR (A58214)
VOLVO EC460CL...
SKID STEER ATTACHMENT SIFT BUCKET (A58214)
SKID STEER...
John Deere 272 Grooming Mower (A59814)
John Deere 272...
