Engine not responding to throttle
/ Engine not responding to throttle #1
bcinlittleaxe
little axe,ok
mahindra 4500
Hey guys need to pick your brain, my 07 4500 is not responding to throttle, when cold it seems to be fine, after about 15 - 20 running it starts cutting out and puffing smoke then after a few minutes it just won't respond when you step on the throttle, but idols fine, I just replace both fuel filters Friday when it first did this, it had run maybe 30 minutes with the new filters before doing it again, any help appreciated
/ Engine not responding to throttle #2
Check flow from tank. You've got a fuel delivery problem somewhere. Maybe tank vent plugged. Take the cap off and see if it makes a difference.
I'll give it a try, it was running good and normal when it all started, the old filters were dirty
/ Engine not responding to throttle #4
It’s common that the bottom of the tank right where the fuel leaves the tank can get plugged. Shine a light down at the bottom when the cap is off. I agree it sounds like a fuel starvation issue.
I actually thought about that a little earlier, I'm go to drain the tank in the morning and pull that screen out and look at it and clean it, thank you for replies, I know we can always count on the tbn folks help
/ Engine not responding to throttle #6
& don't forget.. rubber fuel lines can/will collapse internally.. choking off the fuel..
They will allow enough fuel to be delivered for idle.. but when more fuel is required/needed, it just cant pass..
Heres hopeing its just a clogged screen..
Oh I know that one, me and the parts guy went through about 4 lines last time trying to get the correct one, so I hope it's ok since this one is only 4 or 5 years old
/ Engine not responding to throttle #8
I had a 4025 and it would work fine until it got warmed up good. Then it would lose power and blow white smoke. I thought water was in fuel so I changed filters and didn稚 find any water. I took it to dealership, they found a small crack in the fuel line around injectors. The crack would expand when hot and suck air. They replaced all under warranty. Not sure if this is what youæ±*e experiencing.
That's about what it's doing, it'll run fine when it's cold, after working it for about 15 minutes or so it'll start puffing white smoke for a few minutes and then does not respond at all when I step on the throttle, it's like the throttle is not even hooked up
/ Engine not responding to throttle #10
Sounds more and more lime a tank vent issue. Runs fine until it pulls a vacuum on the tank and stops flow.
BTW, my perm fix for fuel lines was to have the local hydraulic shop replace the braided rubber with braided Teflon. Used the same ends with new farules. Just a couple bucks more than stock replacements.
Thanks that's not a bad idea
Ok guys, I have changed out the fuel line installed new fuel filters, bleed the fuel system twice to get it to start after it died, but still after working 10 - 15 minutes it'll start puffing smoke and cutting out and not talking throttle, I'm about at a loss and really don't want to take it to the dealership
/ Engine not responding to throttle #13
You didn’t mention getting/using fresh fuel.....just another easy SWAG to try.
/ Engine not responding to throttle #15
did you ever figure out the problem?
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2020 Mack Anthem...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
General Guardian/Quiet Source Gen Set (A64912)
General...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
Pallet of Tractor Weights (A64912)
Pallet of Tractor...
1998 Freightliner MT45 Step Van Food Truck (A64556)
1998 Freightliner...
