Engine Manufacturer?
/ Engine Manufacturer? #24
Technically daedong makes them both including the engine. The loaders are different Not sure who built kioti's I think daedong. Bobcat had rhino build there backhoes and early loaders then some where around 2010 bobcat started building there own loaders. I like both tractors a lot but I like the newer bobcat loader the best of the bunch it doesn't lift is high but I believe has higher lift capacity and sits closer to the front of the tractor. Another thing I can't figure out is the CK 27 has one more horsepower than the CT 225 and they seem to be almost identical tractors. I wonder if there truly is a horsepower difference or if it's just marketing.
/ Engine Manufacturer? #25
So I am seriously thinking about buying a CT335 and I realize that I don't know who makes the engine in a Bobcat/Kioti.
Little help?
On the engine will be and ID tag with manufacturer and HP rating. Just pop the hood and look.
/ Engine Manufacturer? #26
All Bobcat white tractors have Daedong (Kioti) engines identical to the Kioti twin tractor. A CT335 is the same as a DK35se. CT445 same as DK45se etc.
2014 Ag Spray Schaben Sidedresser (A56438)
2014 Ag Spray...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
Case Titan 3530 (A61307)
Case Titan 3530...
2010 Ford F550 Bucket Truck with Altec AT37G Boom (A56435)
2010 Ford F550...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
