Engine Manufacturer?
/ Engine Manufacturer? #24
Technically daedong makes them both including the engine. The loaders are different Not sure who built kioti's I think daedong. Bobcat had rhino build there backhoes and early loaders then some where around 2010 bobcat started building there own loaders. I like both tractors a lot but I like the newer bobcat loader the best of the bunch it doesn't lift is high but I believe has higher lift capacity and sits closer to the front of the tractor. Another thing I can't figure out is the CK 27 has one more horsepower than the CT 225 and they seem to be almost identical tractors. I wonder if there truly is a horsepower difference or if it's just marketing.
/ Engine Manufacturer? #25
So I am seriously thinking about buying a CT335 and I realize that I don't know who makes the engine in a Bobcat/Kioti.
Little help?
On the engine will be and ID tag with manufacturer and HP rating. Just pop the hood and look.
/ Engine Manufacturer? #26
All Bobcat white tractors have Daedong (Kioti) engines identical to the Kioti twin tractor. A CT335 is the same as a DK35se. CT445 same as DK45se etc.
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61572)
1984 Charles...
2019 Mirage 20' x 8.5'  Enclosed Trailer (A62613)
2019 Mirage 20' x...
2015Ford Escape SUV (A61574)
2015Ford Escape...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
(APPROX. 34) 2X6X10.5 ROUGH SAWN OAK (A64276)
(APPROX. 34)...
