Engine in M5400
/ Engine in M5400 #1
Edmund
Kubota M5400
I was looking in the Wix filter site for filters for my M5400. They list two engines for the M5400, the F2803 and the V3300. My tractor is used and I bought a used manual for it from another source which says that the 4700 and the 5400 have an F2803. The larger three tractors in that series, the 6800, the 8200 and 9000 (think that's right) have the V3300 engine. What I want to know is did Kubota build some M5400s with the V3300 engine in them and if so how can I tell which engine is in mine?
/ Engine in M5400 #2
I don't have a clue. But, the engine model number is often stamped into the engine somewhere or on a data plate.
You might need a bottle of "simple green" to find it.
/ Engine in M5400 #3
The F-2803 is a 5 cylinder and the V-3300 is a 4 cylinder so that tell you which engine you have. All my info shows the M-5400 to have the F-2803. The model# and serial will be stamped on the block.
J.D.
/ Engine in M5400 #4
All Kubota's are nice running and the five cylinder is so smooth!
/ Engine in M5400 #5
I'm pretty sure the 5-cylinder F2803 engine is used in all of the M4700, M4900, M5400 and M5700's . It was also used in the L5450. It's a great engine. The M6800 has the larger-bore 4-cylinder V3300 engine.
2012 Ford F-250 Crew Cab Pickup Truck (A66736)
2012 Ford F-250...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
500 GAL WATER TANK (A68842)
500 GAL WATER TANK...
2015 John Deere CX15 (A64126)
2015 John Deere...
2018 International Durastar 4300 Asphalt Pot Hole Patcher Truck (A66736)
2018 International...
2015 Freightliner M2 106 Hawk H-1150TL Forestry Grapple Truck (A66736)
2015 Freightliner...
