Engine ideas
/ Engine ideas
I got to see two of the later model conversions that used Bruce's conversion parts at the Mow in,,, nicely done, if ya didnt know Gravely you wouldnt have known it was a conversion, well cept for the empty filler hole in the hood. I also got to hear one running, or should I say I had to listen to hear it running, man was that quiet compared to a Kohler with the pepper pot muffler. A pics for all the pic hounds,,,
/ Engine ideas
I just cant resist posting these, man did they look beastly in person. None of em have engine conversions, all still running the Theads. The only one I remember the tire size for is the wide boy with the duals, axle extensions, and gear reduction, tires were 6x12s. Maybe the owner will see em and give us some details, I did get to talk with him a bit but my JD hat was distracting him,, ya if ya go to a Gravely event dont wear a JD hat,, unless ya got armor plate for skin, all good fun though.
/ Engine ideas #424
I have a 9 horsepower Honda, a 9 horse power Robins & a 10 horse power K241 Kohler all are on 5000 series tranmissions & the 9 horse power tractors are light by about 50 lbs & have as much power & use 1/3rd of the amount of gas that the kohler uses, This I have proved several time to myself. I also have a 1974 model C8 repowered with a 15 horse power Lifan & it is a lot more powerful than anything else I own & it too is easy on gas.
/ Engine ideas #425
I like the Robins better than any of the engines out there to repower with.
/ Engine ideas #426
Well the supplier has sold out of all the cheap Robin 9 Hp Engines.
So anyone fine any cheap good engines let us know
/ Engine ideas #428
The 12 hp machine would be easy to repower, everything to swap in a Briggs with a 1" shaft is available off the shelf, so I could go up to 23hp. Probably handle better with the Briggs, I don't think they weigh as much as the Kohler, but I have a cheap weight set up on the 30" mower to keep the nose down. I know I'm gonna need to do something with the Kohler soon, it's starting to consume a fair bit of oil, not a bug duster yet but gettin close.
If ou want more power, start out with one that had a Kohler and not one with the T head. The T head is expensive to rebuild but it will outlast any other engine by a long shot and they do have collector value. I bought a L recently that had a homebrew Briggs conversion and the first thing I did was took the Briggs and all the machined custom parts off and tossed them off the bridge. Gravely engines are now scarce and I doubt the lower ends and crankcases will be reproduced, although the upper end is all available new....at high prices. High as in more than Harley Davidson prices. A full new top end kit costs what you can buy a good Lycoming cylinder for!
/ Engine ideas #429
Hi guys
Wanted to invite you all:thumbsup:
The HIWASSEE VALLEY ANTIQUE TRACTOR
meet the second week end of Oct .
So this year look like 9 and 10 Oct 2010.
www.hiwasseevallytractorclub.com
14TH ANNUAL HIWASSEE VALLEY ANTIQUE TRACTOR AND ENGINE SHOW |Tractor Show | Iron Memories Antique Tractor Shows, Tractors Rides, Threshing Shows, Old Farm Events
We meet at Charleston TN city Park
Charleston is about 70 Miles south of Knoxville Tenn
Exit 33 on I 75.
From Chattanooga Tn is about 30 miles
There is a trailer park at exit 33
The motels are about 5 to 10 miles at Exit 27 At I 75
Thanks Meet you there
Bruce g
Less do it again Oct 12 2013
/ Engine ideas #430
Does it have a 1 inch crank?
I believe the old Gravely planetary will take more abuse then the 2 speed
or double gear will.
Because the small gears that work with them.
But you have to get the power to it
I bored a gear out to 1.1/8 to fit the large engines like the 24 Honda
Also make a bushing to take a 1 inch crank up to 1.1/8
with key 1/4 X 5/16 X 1.
/ Engine ideas
Ut oh,,, what ya making now Bruce?
/ Engine ideas #433
I have recently acquired the Gravely disease and have 2 mid-60's Super Convertibles. While I like "old stuff", I have to admit I have been wishing for a more useable piece of equipment. I love the idea of repowering one of my C8s! But, I have to admit to being somewhat overwhelmed - there is so much info depending on which model Gravely, which engine you want to use, etc. I am kind of lost at this point.
What basic steps would be involved in putting something like this:
Robin Subaru Horizontal Engine 13 5 HP OHC 1" x 3 5 32" Shaft EH410YD0011 | eBay
on one of my C8s?
I am not afraid of fabrication and "re-engineering". I have a 14" South Bend lathe and a Bridgeport and know how to use them.
Are there other engines that would be an easier fit? Is there an "easiest"?
I know, I have lots of questions!
Thanks,
Wally
/ Engine ideas
I think there was discussion in the thread about similar engines? Most "modern" engines use a standard bolt pattern, and all one needs to do is compensate for shaft length.
/ Engine ideas #435
I am picking up a 9HP Subaru today just a few miles from my house. Smaller than I wanted, but it is new and I'm getting it for $200 - really can't pass it up. Figure I'll get my feet wet with it anyway.
I know that what I'm asking has been answered, it's just that all of these different repowers/threads run together and I get confused. So, since I have a C8 with a Gravely engine, I need something like a "Kohler adapter", a spacer, and a gear to fit the shaft of my engine that will work with the 3600 RPM speed?
- Can I make an adapter out of steel plate?
- Can I get a gear and bore/broach? (I think this 9HP might have a 7/8" shaft)
What am I missing?
Thanks,
Wally
/ Engine ideas
Well 11 or 13 hp would be better as the engines are not run at 3600 rpm but 9hp should work for bout everything cept snowblowing, it would likely work for that also it just might be slow? I have a 12hp Kohler and its rare for me to be at full throttle except for snowblowing.
I know Bruce (gravelymay) uses a Kohler plate and then an aluminum spacer, he has also made the adapter gears for the L models, if you dont have the tools or access to them PM him he was making parts for folks. One could make the spacer with just about anything but the key is to keep everything lined up,, the gear, well others have written their ideas/approach in the thread.
/ Engine ideas #439
Well Wally it has been a year
and I have not heard from you or any one else.
Sadly, my Gravelys - and all other projects - are sitting idle while I get my new shop together. I am so close... I have a few more gas line connections for the radiant heat (woohoo!) and a little painting to do.
Once done, I will have the shop I've always dreamed of! As far as the Gravelys, I am leaning more towards selling one of the C8s and getting a 526x or other model that already has a Kohler on it. Still looking for something to use the little 9HP Subaru for... Maybe a log splitter.
Thanks,
Wally
MULTIQUIP  Whisperwatt 25 Pull Behind Generator (A62613)
MULTIQUIP...
2012 Ford E-350 Passenger Van (A61573)
2012 Ford E-350...
2016 Dodge Grand Caravan Van (A61574)
2016 Dodge Grand...
Ripper Tooth Excavator Attachment (A61567)
Ripper Tooth...
JRB 52" HANG-ON WHEEL LOADER FORKS (A63276)
JRB 52" HANG-ON...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A59911)
2005 KENWORTH T800...
