engine help lb 1914
/ engine help lb 1914 #1
truckfix
kioti lb1914,kubota8200
picked up this tractor as a project. cheap,, its in great shape other than the engine.it was not cared for in anyway. p o said it had a bad headgasket. so i pulled the head . there was antifreeze in the pan,,2bent pushrods number 2 liner is cracked .everything else seems ok. the head is at the machine shop for magnafluxing. my question is has anyone did the kobata d 950 switch in there kioti from the daedong td 950.kioti has new engines about 7000.they donot rebuild old engines, i found a rebuilt kabota d 950 for half the money. probably been asked this question alot.the tractors not worth a 7000 engine. thanks for any info on this subject.
/ engine help lb 1914 #2
thanks alot for the reply. ive read that the kabota d950 from a 8200 would bolt right in to the chasis and transmission but then i did a little more digging and read that it wouldnt. i just dont want to spend the money if no one deffinately knows. depending on what the machine shop says about the head i might just rebuild the td 950. its about the same money just more time involved especially with ordering parts. i notice kabota sells 950 rebuild kits but daedong parts have to be ordered seperately. its to bad they dont rebuild these engines.
/ engine help lb 1914 #4
If you need a head, let me know. I've got one for sale in the Classified section here. Might make a better deal than what I've got it priced at.
Ok thanks I'll keep it in mind.I'm still waiting on the machine shop.
/ engine help lb 1914 #6
I could swear that I read previous posts about this engine and they are/where used in reifer trailers for the refrigeration units and a member found one that way. Just a thought. Maybe do a search for previous posts.
/ engine help lb 1914 #7
That model kioti will use the Kubota engine! Drop in!
art do you know if any yr d950 will work. i have a lead on a d950 i dont know how to figure out the serial number for the yr of the engine. kabota d950 686414 is what i got. can any one tell the yr? thanks
/ engine help lb 1914 #9
ever figure anything out im in the same boat.
2026 Deere 320P (A64126)
2026 Deere 320P...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A64556)
2019 Ford F-150...
2010 KEYSTONE LAREDO (A65643)
2010 KEYSTONE...
Case 1150G Dozer (A66285)
Case 1150G Dozer...
Mitas Tire (A65640)
Mitas Tire (A65640)
Stout Rock Bucket Grapple HD72-3 (A66285)
Stout Rock Bucket...
