engine help lb 1914
   / engine help lb 1914 #1
truckfix
kioti lb1914,kubota8200
picked up this tractor as a project. cheap,, its in great shape other than the engine.it was not cared for in anyway. p o said it had a bad headgasket. so i pulled the head . there was antifreeze in the pan,,2bent pushrods number 2 liner is cracked .everything else seems ok. the head is at the machine shop for magnafluxing. my question is has anyone did the kobata d 950 switch in there kioti from the daedong td 950.kioti has new engines about 7000.they donot rebuild old engines, i found a rebuilt kabota d 950 for half the money. probably been asked this question alot.the tractors not worth a 7000 engine. thanks for any info on this subject.
   / engine help lb 1914 #2
thanks alot for the reply. ive read that the kabota d950 from a 8200 would bolt right in to the chasis and transmission but then i did a little more digging and read that it wouldnt. i just dont want to spend the money if no one deffinately knows. depending on what the machine shop says about the head i might just rebuild the td 950. its about the same money just more time involved especially with ordering parts. i notice kabota sells 950 rebuild kits but daedong parts have to be ordered seperately. its to bad they dont rebuild these engines.
   / engine help lb 1914 #4
If you need a head, let me know. I've got one for sale in the Classified section here. Might make a better deal than what I've got it priced at.
Ok thanks I'll keep it in mind.I'm still waiting on the machine shop.
   / engine help lb 1914 #6
I could swear that I read previous posts about this engine and they are/where used in reifer trailers for the refrigeration units and a member found one that way. Just a thought. Maybe do a search for previous posts.
   / engine help lb 1914 #7
That model kioti will use the Kubota engine! Drop in!
art do you know if any yr d950 will work. i have a lead on a d950 i dont know how to figure out the serial number for the yr of the engine. kabota d950 686414 is what i got. can any one tell the yr? thanks
   / engine help lb 1914 #9
ever figure anything out im in the same boat.
2006 TOYOTA Highlander SUV (A50324)
2006 TOYOTA...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
2007 BMW 750Li (A50324)
2007 BMW 750Li...
Kinkaid 1200 LS-PH Towable Hydroseeder (A51691)
Kinkaid 1200 LS-PH...
Red Iron Oxide in Trace Mineral Supplements for Cattle
Red Iron Oxide in...
John Deere 24" Backhoe Bucket (LOCAL TOWNSHIP) (A50774)
John Deere 24"...
