Engine exchange with water pump issue
/ Engine exchange with water pump issue #1
Dallas1955
B8200
I have a B8200 4 wheel drive kubota with a d950 engine and
Put a rod through the engine block I purchased a d850 engine
that has a dynamo instead of a water pump but was told
I could replace front engine cover on the d850 with engine cover
from my d950 . The problem? , d850 doe not have
Water pump hole in engine above gears and where the dynamo
Is behind the fan on the block is a brass plug which seems
like it would block complete water distribution through
engine. Any help would be appreciated
Thanks, Dallas
/ Engine exchange with water pump issue #2
First, Welcome to TBN!
Second, sounds like someone, whoever advised you about the interchangeability, might be misinformed about same?
Have you gone back to them with this problem for a further discussion/explanation?
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
New/Unused Landhonor Toolbox with 24 Ratchet Straps (A65583)
New/Unused...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
Hays LT1 Tender (A61307)
Hays LT1 Tender...
Ellis Band Metal Saw (A62679)
Ellis Band Metal...
Caterpillar C18 Industrial Diesel Engine - Serial N8F01121 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
