Engine exceeding RPM after rebuild?
   / Engine exceeding RPM after rebuild? #1
ran007
Hey guys,
I spent some time recently rebuilding my Kohler Command Pro 21.. Cleaned carb, replaced breather tube, changed fuel, oil & air filter, and just generally made it look like new. I also noticed that the throttle on the carb was a little sticky in the process, so I cleaned that up and lubed it. Finally, I adjusted the throttle assembly mechanism arms and springs - and I think I went too far.
Well, the engine cranked right up, like new even, but the second I increase the throttle, the engine feels like it revs up waaay too high and too fast...
Does anyone have any experience with the throttle assembly mechanism, or know if what I did could have caused my problem?
Thanks for the help!
   / Engine exceeding RPM after rebuild? #2
get engine model/type/etc. # off engine plate. go to kohler website. D/l service manual. May contain detailed directions for carb adj/troubleshooting.
Yeah, I have a service manual. I'm thinking that the governor lever simply needs to be reset and re-torqued correctly. I took that stuff all apart to clean, put it back together not really noting the settings.
   / Engine exceeding RPM after rebuild? #4
Near the end of section 5 of the service manual will tell you how to adjust the governor.
Ditch Witch 6510A Trencher - Deutz Diesel, Backhoe, Cable Plow, Front Blade (A56435)
Ditch Witch 6510A...
Year: 2017 Make: Dodge Model: Grand Caravan Vehicle Type: Van Mileage: Plate: Body Type: 4 Door V... (A55758)
Year: 2017 Make...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
2015 Freightliner Squirt Bucket Truck (A55973)
2015 Freightliner...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A55315)
2023 New Holland...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
