Engine exceeding RPM after rebuild?
   / Engine exceeding RPM after rebuild? #1
ran007
Hey guys,
I spent some time recently rebuilding my Kohler Command Pro 21.. Cleaned carb, replaced breather tube, changed fuel, oil & air filter, and just generally made it look like new. I also noticed that the throttle on the carb was a little sticky in the process, so I cleaned that up and lubed it. Finally, I adjusted the throttle assembly mechanism arms and springs - and I think I went too far.
Well, the engine cranked right up, like new even, but the second I increase the throttle, the engine feels like it revs up waaay too high and too fast...
Does anyone have any experience with the throttle assembly mechanism, or know if what I did could have caused my problem?
Thanks for the help!
   / Engine exceeding RPM after rebuild? #2
get engine model/type/etc. # off engine plate. go to kohler website. D/l service manual. May contain detailed directions for carb adj/troubleshooting.
Yeah, I have a service manual. I'm thinking that the governor lever simply needs to be reset and re-torqued correctly. I took that stuff all apart to clean, put it back together not really noting the settings.
   / Engine exceeding RPM after rebuild? #4
Near the end of section 5 of the service manual will tell you how to adjust the governor.
BUNDLE OF 22" X 60" EXPANDED METAL (A57192)
BUNDLE OF 22" X...
Nissan Forklift (A55973)
Nissan Forklift...
(APPROX 10) UNUSED SDLANCH RATCHET STRAPS (A57192)
(APPROX 10) UNUSED...
Enmark Z Spray (A53316)
Enmark Z Spray...
2007 Caterpillar D5G LGP (A53317)
2007 Caterpillar...
2012 Infiniti G25 Sedan (A56859)
2012 Infiniti G25...
