Engine exceeding RPM after rebuild?
   / Engine exceeding RPM after rebuild? #1
ran007
Hey guys,
I spent some time recently rebuilding my Kohler Command Pro 21.. Cleaned carb, replaced breather tube, changed fuel, oil & air filter, and just generally made it look like new. I also noticed that the throttle on the carb was a little sticky in the process, so I cleaned that up and lubed it. Finally, I adjusted the throttle assembly mechanism arms and springs - and I think I went too far.
Well, the engine cranked right up, like new even, but the second I increase the throttle, the engine feels like it revs up waaay too high and too fast...
Does anyone have any experience with the throttle assembly mechanism, or know if what I did could have caused my problem?
Thanks for the help!
   / Engine exceeding RPM after rebuild? #2
get engine model/type/etc. # off engine plate. go to kohler website. D/l service manual. May contain detailed directions for carb adj/troubleshooting.
Yeah, I have a service manual. I'm thinking that the governor lever simply needs to be reset and re-torqued correctly. I took that stuff all apart to clean, put it back together not really noting the settings.
   / Engine exceeding RPM after rebuild? #4
Near the end of section 5 of the service manual will tell you how to adjust the governor.
2006 Toyota Tundra 4X4 Pickup Truck (A50323)
2006 Toyota Tundra...
2014 International Durastar 4300 Terex BT2047 47ft Crane Truck (A50323)
2014 International...
FORD COBRA REPLICA RACING CAR (A51222)
FORD COBRA REPLICA...
2020 KUBOTA RTV...
Walking Floor Trailer (A50322)
Walking Floor...
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
