Engine drive shaft coupler to hydraulic pump failure. Need help!
   / Engine drive shaft coupler to hydraulic pump failure. Need help!
I also have NH hydraulics sizing up a loader and lift cylinder seal kit and should be ready tomorow. I had one kit that came with the tractor when I bought it. I brought it to them to make a 3 more. It will be interesting to see what their price comes in at.
   / Engine drive shaft coupler to hydraulic pump failure. Need help! #42
They tend to dry out when they sit on the bench for any length of time. Mine was fine before I had to take it apart. It sat for about 3 months while I managed to repair the coupler between the drive motor and the differential. When I put it all back together it leaked. First a little and after several hours of use it became a problem :(
   / Engine drive shaft coupler to hydraulic pump failure. Need help! #43
Did you get the seal kit?
   / Engine drive shaft coupler to hydraulic pump failure. Need help! #44
Hello: I think I have also stripped out my Kohler coupler.
How did you make out on your project?
   / Engine drive shaft coupler to hydraulic pump failure. Need help! #45
I ended up pulling the pump and it looks like the spines at the engine stripped out.
The splines on the pump shaft look OK.
Next is to order the part from Kohler.
LOT: Welding Power Leads, 220V Electrical Cord (A59076)
LOT: Welding Power...
Takeuchi TB145 (A55272)
Takeuchi TB145...
2015 MACK CXU613 TANDEM AXLE SLEEPER TRUCK (A59575)
2015 MACK CXU613...
JOHNSON SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON SEAHORSE...
2013 International DuraStar 4400 T/A Box Truck (A56858)
2013 International...
CLUB CAR  CARRYALL 6 (A58214)
CLUB CAR CARRYALL...
