Engine cutting out...Kubota B7800
   / Engine cutting out...Kubota B7800 #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
I was operating my Kubota B7800 yesterday and noticed that the engine briefly cut out.
Once as I was backing up, and once while I was beginning to accelerate up a small grade with a load.
Can there be a problem with the seat switch?
Not sure if the former owner bypassed the seat switch?
   / Engine cutting out...Kubota B7800 #2
This could easily be the seat switch. I had a similar issue and ended up bypassing it to resolve.
   / Engine cutting out...Kubota B7800 #4
Find the wires under seat, pull them off and tape them up.
   / Engine cutting out...Kubota B7800 #5
water in fuel?
   / Engine cutting out...Kubota B7800 #6
last time you change fuel filter?
Put a new fuel filter in 13 months ago/75 hours on the new filter.
Should I replace it?
   / Engine cutting out...Kubota B7800 #8
Depends on how dirty the fuel and/or the tank is. Make sure the tank strainer is not clogged as well as the filter and fuel lines. Make sure the fuel line connections are tight and the lines are not damaged or pinched.
I am new to tractors. Can you tell me where to find the tank strainer? Can it be removed to inspect and clean?
There is no fuel shut off that I can see. The manual says to remove the clear cover and the fuel will stop flowing.
Is this the correct way?
   / Engine cutting out...Kubota B7800 #10
My friend's wife had that problem with a used BX. Turned out she wasn't heavy enough for the safety switch under the seat. Turned out there are two plates which work as spacers for the sensor. I removed one plate. No more problem.
2012 Nissan Rogue (A50324)
2012 Nissan Rogue...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50775)
ALL TITLED ITEMS...
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52748)
NEVER USED FECON...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
