Engine cutting out...Kubota B7800
   / Engine cutting out...Kubota B7800 #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
I was operating my Kubota B7800 yesterday and noticed that the engine briefly cut out.
Once as I was backing up, and once while I was beginning to accelerate up a small grade with a load.
Can there be a problem with the seat switch?
Not sure if the former owner bypassed the seat switch?
   / Engine cutting out...Kubota B7800 #2
This could easily be the seat switch. I had a similar issue and ended up bypassing it to resolve.
   / Engine cutting out...Kubota B7800 #4
Find the wires under seat, pull them off and tape them up.
   / Engine cutting out...Kubota B7800 #5
water in fuel?
   / Engine cutting out...Kubota B7800 #6
last time you change fuel filter?
Put a new fuel filter in 13 months ago/75 hours on the new filter.
Should I replace it?
   / Engine cutting out...Kubota B7800 #8
Depends on how dirty the fuel and/or the tank is. Make sure the tank strainer is not clogged as well as the filter and fuel lines. Make sure the fuel line connections are tight and the lines are not damaged or pinched.
I am new to tractors. Can you tell me where to find the tank strainer? Can it be removed to inspect and clean?
There is no fuel shut off that I can see. The manual says to remove the clear cover and the fuel will stop flowing.
Is this the correct way?
   / Engine cutting out...Kubota B7800 #10
My friend's wife had that problem with a used BX. Turned out she wasn't heavy enough for the safety switch under the seat. Turned out there are two plates which work as spacers for the sensor. I removed one plate. No more problem.
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 VOLVO VNM DAY CAB (A51222)
2017 VOLVO VNM DAY...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
