Engine cuts out, JD 318
/ Engine cuts out, JD 318 #1
doctoricar
Indianapolis, IN
JD 318
I have a JD 318 1986, When the engine is run for approximately one and a half hours it appears to be having a breakdown in the ignition. it dies, then runs. I only have this problem when hot. does not die all the way just cuts in and out. Onan engine
/ Engine cuts out, JD 318 #2
They have a pickup under the flywheel, it could be the coil, but I had to replace my pickup this summer. If you google onan test procedures you will find how to test the pieces. My coil was out of spec and I replaced it. ran the exact same way. ended up buying a pickup online as it was 1/3 of what the JD dealer wanted. runs better than ever.
/ Engine cuts out, JD 318 #3
I found on my Steiner that the molex connectors that carried the wiring had limited electrical contacts. By cleaning them and readjusting the pins within the connector it made it reliable again. Mine too was cutting out and I tried replacing plug wires, coil and plugs before I found the connector to be the issue. It too only did it while hot.
That was three years ago. Still have my spare parts in case I need them to troubleshoot it again.
Steve
2020 JOHN DEERE 325G SKID STEER (A65056)
2020 JOHN DEERE...
2018 JOHN DEERE 350G LC EXCAVATOR (A65056)
2018 JOHN DEERE...
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2019 COLEMAN BT200X MINI-BIKE (A64280)
2019 COLEMAN...
2015 Freightliner M2 106 Ambulance (A66736)
2015 Freightliner...
DAYTON 110,000 BTU OIL FIRED HEATER (A64276)
DAYTON 110,000 BTU...
