Engine block heater for BX 1500
   / Engine block heater for BX 1500 #1
Lvm
Michigan
bx 1500
I did a search for the BX 1500 but came up empty. Please help, if possible with pictures.
   / Engine block heater for BX 1500 #2
I dont have a block heater in my BX1500 but here is the option # for heater
70000-00298. Here is a link to Messicks web site with the part.
Part Search
Oh by the way welcome to TBN
   / Engine block heater for BX 1500 #3
can alwaus use a magnet block heater as well..
soundguy
   / Engine block heater for BX 1500 #4
The magnet idea is pretty good, since it would be a rather cold and unpleasant task to do right now. We are expecting lows in mid single digits by week's end. We are also expecting 12" of snow on Wednesday, on top of the 5 we got this morning.
I just came in to warm up from plowing for over an hour. I have a dealer installed, (assumes Kubota) block heater. Gotta have it up here.
   / Engine block heater for BX 1500 #5
soundguy
I've never heard of a magnetic heater? Sounds easy enough though?
Pricey to buy? Use?
   / Engine block heater for BX 1500 #6
Pricey to buy? Use?
I googled magnetic block heater and got 72,000 hits. The first 10 showed some sources and prices.
   / Engine block heater for BX 1500 #7
I installed a heater hose heater in our 1973 220D. It worked great on a -22 F morning in Vermont.
Found mine in the JC Whitney catalog. They're on line now; I think.
Ralph
   / Engine block heater for BX 1500 #8
Pricey to buy? Use?
easy and not terribly pricey.
you can use a few of them.. IE.. one on the hyds or common sump, and one on the oil ban.. and block.. plus a trickle charger for the battery.. get a couple cheap timers and use correct extension cables and rated outlets and set it up so that 2 hours before you go out in the morning the heaters and charger kick on.. that gives you a warm topped off battery and warm engine oil, and warmed hyd oil..
soundguy
   / Engine block heater for BX 1500 #9
soundguy
That's cheating! LOL
EXCAVATOR GRAPPLE (A53843)
EXCAVATOR GRAPPLE...
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
2022 CATERPILLAR 242D3 SKID STEER (A51406)
2022 CATERPILLAR...
2020 BOBCAT T870 SKID STEER (A52705)
2020 BOBCAT T870...
2013 BRENNER 250BBL TRI-AXLE ALUMINUM TANK TRAILER (A53843)
2013 BRENNER...
ACETYLENE TORCH CART WITH GAUGES AND HOSES (A53843)
ACETYLENE TORCH...
