Engine bearings source?
/ Engine bearings source? #1
Massey1010
Willamette Valley
I'm trying to find replacement engine bearings for my Massey Ferguson 1010 made by Hinomoto. The engine is a 3 cylinder Toyosha CS86. If anyone knows where I can locate some bearings for this engine I would appreciate it.
/ Engine bearings source? #2
I would think any bearing supplier would be able to get what you need - if they don't have them in stock.
If you can find a three or four digit number on the bearing/s they can work from that or if you can give them ID, OD and thickness, they can probably look up the bearing number.
/ Engine bearings source? #3
Go to an engine rebuild shop, they can make them for you.
I forgot to mention that these are not regular roller bearings but rather more like bushings. It does seem odd to me that they would have used something like that. They resemble strips of metal about 3/4" wide bent into a full circle. I'm not sure what they are made out of either. I had never seen anything like this before.
/ Engine bearings source? #5
That is a style very typical of Asian built engines. The crankshaft is fully supported by the block rather than cradled by main bearing caps.
/ Engine bearings source? #6
What does the Massey parts people say? How would the crankshaft get in assembled into the block? I would think it would have to have conventional automotive type shell bearings, the half circle type. bjr
/ Engine bearings source? #7
My advice is to contact one of the grey market parts suppliers and see if the parts are available from Japan. Google "Hinomoto parts" and you should be able to find a number of parts suppliers that may be able to get them.
UNUSED JCT QUICK ATTACH 60" PALLET FORKS (A62131)
UNUSED JCT QUICK...
DURA-CAST PRO-LICK TANK (A62131)
DURA-CAST PRO-LICK...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
UNUSED WOLVERINE BC-13-72W 72" HYD BRUSH CUTTER (A62131)
UNUSED WOLVERINE...
Polaris Sportsman 570 EFI Four Wheeler (A61166)
Polaris Sportsman...
UNUSED ATS ACE80-80 GALLON ELEC. AIR COMPRESSOR (A62131)
UNUSED ATS...
