engine backfires while starting john deere 175
/ engine backfires while starting john deere 175 #1
davefrommd
My neighbors john deere 175, kawasaki 17hp engine usually backfires while starting. We just removed the flywheel and replaced the flywheel key and it still backfires. The carburetor was previously removed and john deere rebuilt it. We never adjusted the carburetor and was wondering if that could be the problem. I'd be interested in any suggestions or comments. Thanks in advance for your help. dave
/ engine backfires while starting john deere 175 #2
Dave , If it is backfiring through the carb its probably a deposit on the intake valve making it stick open ,But it probably wouldn't run, It sounds as if it runs?? It could be Marginal.
If its backfiring through the exhaust it is probably a burnt exhaust valve, A compression test would help to determin which cylinder is the culprit.
Or it could be the carb dropping to much fuel? Lots of maybees but it all needs to be looked at,
Also is it the first start of the day or every start ?
OH and welcome to TBN... /forums/images/graemlins/smile.gif
/ engine backfires while starting john deere 175 #3
My guess would be the ignitor. It is a little silver looking box with a wire coming out of it on the left side of the motor. Usually when the ignitor starts going south it will begin with the backfire at start up. That little box is about $35 to $50 depending on where you get it.
/ engine backfires while starting john deere 175 #4
We just had a 175 in the shop with the same problem described. It would backfire on startup. As the condition worsened, it would not start at all. We ended up replacing the ignition coil and that cured it.
2008 Toyota Rav4 SUV (A61569)
2008 Toyota Rav4...
UNUSED WOLVERINE QC5-26-2DG QUICK ATTACH (A62131)
UNUSED WOLVERINE...
Gleaner N630 Corn Head (Allis Chalmer Branded) (A61307)
Gleaner N630 Corn...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
2007 Dodge Ram 2500 Service Truck with Crane, VIN # 3D7KR26D67G784488 (A61165)
2007 Dodge Ram...
Volvo EC220EL (A60462)
