Engaging the PTO
/ Engaging the PTO #1
lewispmills
McKee, Kentucky
Case IH 5130 and John Deere 550 Dozer and Yanmar VIO50 Excavator and Case 1845C skid steer and Kioti LK3054 & Case IH Farmall 80 4wd w/cab and fel
I have a 2000 Kioti 3054 that I recently bought off my father-in-law. Every time I engage the PTO it rakes the gears and the clutch does not seem to work the PTO. I ask my father-in-law about it and he said it had always done that. Are there a way of adjusting the PTO clutch or what??
Lou
/ Engaging the PTO #3
It could be one of a couple of problems. Is there a noise coming from the clutch area when you push the pedal in? If so, it could either be a failed release (thrust) bearing or a finger (lever) bolt may have either come undone or just worn out or possibly both, this then does not allow enogh travel of the fingers to release either the main clutch or the PTO clutch.
If there is no noise and it is the PTO engagement that is the problem, there is an internal adjustment on the clutch that needs to be done. I am not sure if there is an access plate on the side of the bell housing to allow the adjustment to be done without splitting the tractor, if there is, you should be able to get a look at the thrust bearing and the fingers at the same time. The adjustment is 40 thou and there should be three bolts and lock nuts evenly spaced around the clutch unit. The only tools you will need are a couple of 13 or 14mm R & OE spanners and a feeler gauge. I am sorry I do not know if there is the access plate to see in there, but I am not 100% familiar with this model. But maybe someone else can shed some light on this for you.
/ Engaging the PTO #4
lewispmills there is a inspection cover on the left side of the bell housing two 12mm bolts, , I had to ajust mine, its a pain to do but fairly simple procedure.
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
Rigging, Binding, Chain & Lifting Equipment (A66408)
Rigging, Binding...
2020 CATERPILLAR 140 AWD MOTORGRADER (A63276)
2020 CATERPILLAR...
2008 Case IH JX80 Loader Tractor (A66285)
2008 Case IH JX80...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
208735 (A60430)
208735 (A60430)
