SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 12,505
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
Well, your first post mentions a simple kit and implies that you can make a 30,000W generator to run a house with a simple kit.
That graphic you show for the 30,000w Prius is the 2000 RPMs of the generator to produce 30,000W. How many RPMs does the gas engine have to turn to produce that much power??? 5000 RPMS. Here's the source.
Prius Specifications
OK. Im not buying anywhere near as low as 6KW limit. ... If you review the Prius spec link provided by MossRoad above youll find the traction batt peak rating to be 21 or 27 kW depending on model. Reduce this by half and you still have more than 10kW available to pull thru a sine inverter at 1/2 batt rating. And thats NOT counting the active charge available to the batt with engine on line. All thats needed is the appropriate electronic interface to "task" the composite hybrid system and ultimately to go from 200VDC to 240 60HZ w neutral.There is a short 530+ message thread over on Priuschat.
From my reading of that thread you would be putting your Prius in danger if you hook up directly to the "traction battery". What almost everyone is doing is running their converters off the 12V battery and drawing up to 5 KW max. I've yet to find any reference where I could relatively easily hook a Prius up to the house and expect to be able to pull 30KW off it so I could run my welder and cook a turkey in my electric oven.
The main advantage of the Prius as a 3 to 5KW generator is that it automatically starts the engine, charges up the traction battery, which charges up the 12V battery, which is hooked to some form of plug out kit.
Basically an autostart generator attached to a battery bank.
/edit
Here's a response to my request for being able to pull even 15KW off a Prius:
So although the ENGINE may be rated a XXHP/KW it ain't gonna happen anytime soon.
