Ends that fit remotes?
/ Ends that fit remotes? #1
sparkkky
Oklahoma
Kubota B21
Got a used cylinder with JD ends, what does the Kubota require and where's the best place to buy them?
/ Ends that fit remotes? #3
What do you mean by JD ends? The male quick coupler fittings that are used by JD?
There is no specific "JD" type or brand of coupler.
However, there are several different styles and sizes of quick couplers available in the marketplace. You have to get the part numbers from the male and female ends and match them up. Any good hydraulic shop or online source like Discount Hydraulic Hose has a cross reference chart and should be able to help you.
Here is a link to an online chart. It's good for reference but DO NOT buy from this place. Service and delivery is spotty at best, if you get your stuff at all.
Coupler cross reference charts
/ Ends that fit remotes? #4
What style will fit my factory Kubota remotes, is it the same as the Deere?
/ Ends that fit remotes? #7
JD uses several different styles and sizes depending on what tractor and what implement it was on.
Kubota also uses several diferent styles and sizes depending on what the application is.
You have got to match numbers to see what you have.
It is probably cheaper to buy male ends for the cylinder hose that match the Kubota QD than it is to change the QD on the tractor.
/ Ends that fit remotes? #8
/ Ends that fit remotes? #9
If the cylinder was being used on an old JD, then it very well could have JD ends on it. JD, Case and IHC all had their own specific connector designs at one time. I don't know when they quit using the brand specific models, but it was at least 30 years ago. Here are examples of the types that were available.
/ Ends that fit remotes? #10
/ Ends that fit remotes? #11
Hello….All Kubota I have seen you use a Pioneer end, it is the ½ inch with a round ball at the end not the one with a pointy tip on the check ball. You can get them at Tractor Supply or any place like that. KrnnyV.
/ Ends that fit remotes? #12
/ Ends that fit remotes? #13
I don't know any names or specs but my B-I-L gave me a set of adapters that accept the male ends from a big JD mower and plugs into the rear remotes on my L4400. So it may be easier to get an adapter than refitting the cylinder hoses or the tractor. The adapter works like a charm.
/ Ends that fit remotes? #14
Thanks, guys it is the pioneers.
2017 GMC 3500 Enclosed Service Body Truck (A62613)
2017 GMC 3500...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2023 73in Vibratory Roller Skid Steer Attachment (A61572)
2023 73in...
2014 Dodge Grand Caravan Van (A61574)
2014 Dodge Grand...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A61573)
2017 Ford F-150...
