Emergency ditch opener needs Top 'n Tilt
   / Emergency ditch opener needs Top 'n Tilt #1
i7win7
Elite Member
Central, IL
kubota bx2370, b2650, ford 4000
Made this 8 or 9 years ago. Idea was to open drainage ditch after a mudslide and minimize damage to hillside drive. Wondered if I should dismantle it and salvage the carryall. Tried it today, definitely need TnT, not sure if a solid digging tooth would be better. It is an emergency tool to keep water flowing until drive is repaired and ditches can be cleaned.
https://www.tractorbynet.com/forums/videos/426238-talk-about-white-knuckels-3-a.html?highlight=
Ideas to improve this tool or photos of your "ditch cleaner" appreciated.
   / Emergency ditch opener needs Top 'n Tilt #2
   / Emergency ditch opener needs Top 'n Tilt #3
Do you have a rear blade?
Bruce
Ratchet rake wrong tool for job. I have a box blade, several other implements. Looking down from hillside you can see a mudslide and condition of drive after land planing. Not yet ready for ditch cleaning, expecting 2 more days of rain before I have 3 decent days to clean it out.
In recent past, drainage ditches have been reinforced with construction blocks and rip-rap gravel. Both hard on 3pt blades and box blades.
Best solution may be sell place, move to the flat lands.
   / Emergency ditch opener needs Top 'n Tilt #5
Can you please ID the cars in the pic of the middle busters ??..thanks...just curious...
mazda rx3, amc eagle
   / Emergency ditch opener needs Top 'n Tilt #8
My suggestion were a couple of items 1) a rear blade that offsets. The greater ability to offset the better for cleaning out the ditch. But not much use for rip-raft rocks. 2) a back hoe. This would seem to be a better item with the rocks in place. And you have one! 3) a pressure washer to loosen the mud more and let it flow away down the hill.
2018 Chevrolet Tahoe SUV (A56859)
2018 Chevrolet...
2018 John Deere 4066R (A53314)
2018 John Deere...
2021 Ford F-450 (A55973)
2021 Ford F-450...
1629 (A57192)
1629 (A57192)
2017 Bobcat T770 Compact Track Loader (A56435)
2017 Bobcat T770...
2013 Freightliner M2 106 16ft Stakebody Flatbed Truck with Liftgate (A55852)
2013 Freightliner...
