Emergency ditch opener needs Top 'n Tilt
   / Emergency ditch opener needs Top 'n Tilt #1
i7win7
Elite Member
Central, IL
kubota bx2370, b2650, ford 4000
Made this 8 or 9 years ago. Idea was to open drainage ditch after a mudslide and minimize damage to hillside drive. Wondered if I should dismantle it and salvage the carryall. Tried it today, definitely need TnT, not sure if a solid digging tooth would be better. It is an emergency tool to keep water flowing until drive is repaired and ditches can be cleaned.
https://www.tractorbynet.com/forums/videos/426238-talk-about-white-knuckels-3-a.html?highlight=
Ideas to improve this tool or photos of your "ditch cleaner" appreciated.
   / Emergency ditch opener needs Top 'n Tilt #2
   / Emergency ditch opener needs Top 'n Tilt #3
Do you have a rear blade?
Bruce
Ratchet rake wrong tool for job. I have a box blade, several other implements. Looking down from hillside you can see a mudslide and condition of drive after land planing. Not yet ready for ditch cleaning, expecting 2 more days of rain before I have 3 decent days to clean it out.
In recent past, drainage ditches have been reinforced with construction blocks and rip-rap gravel. Both hard on 3pt blades and box blades.
Best solution may be sell place, move to the flat lands.
   / Emergency ditch opener needs Top 'n Tilt #5
Can you please ID the cars in the pic of the middle busters ??..thanks...just curious...
mazda rx3, amc eagle
   / Emergency ditch opener needs Top 'n Tilt #8
My suggestion were a couple of items 1) a rear blade that offsets. The greater ability to offset the better for cleaning out the ditch. But not much use for rip-raft rocks. 2) a back hoe. This would seem to be a better item with the rocks in place. And you have one! 3) a pressure washer to loosen the mud more and let it flow away down the hill.
2023 Kubota KX057-5 Compact Excavator (A56436)
2023 Kubota...
2013 John Deere 824K Wheel Loader (A56435)
2013 John Deere...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58214)
2025 GIYI MULCHER...
2012 Dodge Grand Caravan (A56859)
2012 Dodge Grand...
