Oil & Fuel Emax 25 Stalling, Trouble Starting
/ Emax 25 Stalling, Trouble Starting #1
Airportbum365
Penetanguishene Ontario
Ford LGT 14D and Mahindra E-max 25 TLB
I have an Emax 25 TLB I have been having this intermittent issue with the fuel
When starting the tractor will run at very low idle no matter what position the throttle is in
And some times stall out other times it will idle right up after some time To me it sound like a fuel pressure issue. I have replace the fuel filter but looking for some direction on this issue before I buy a new fuel pump TIA
/ Emax 25 Stalling, Trouble Starting #2
Start by checking for adequate fuel flow at various points in the system. Gravity flow from tank, before and after fuel filter, before and after lift pump, etc...
Flex the rubber lines to check for cracks that can suck air, confirm the lift pump is operating, blow out the lines with compressed air. Also some fuel shutoff valves on filters have been known to have inlet screens that can clog.
Good luck!
Thanks for the advice first off
I checked the fuel flow at various points all the way to the lift pump. Lots of fuel coming out of the lift pump before it goes into the injector pump all the lines seem to be in good shape I replace 1 line so far from the lift pump to the injector pump with no result yet
The problem seems to only happen when the tractor has been shut off for some time
I will try and start it about 4 or 5 times stalling in between and running for 10 seconds each time at which point it will try and keep running longer at about 8 starting attempts it will continue to run but will not idle up with no stalling. After about ten minutes it will idle right up with no hesitation
And continue to run with no issues as long as I don’t shut it down. It will start right up no problem as soon as I shut it down
but if it sits for a couple of hours the problem returns
I will continue to troubleshoot but any advice would be greatly appreciated TIA
/ Emax 25 Stalling, Trouble Starting #4
Are the glow plugs working properly? My eMax 25 has the Daedong engine . It's good but cold blooded! I had an occasion the plugs didn't work and it was a tough start with stalling, choking and puking!
My apologies for not writing back on what the issue was back in 2022 but I took it to the dealer and they diagnosed the issue
It was a bad fuel actuator
/ Emax 25 Stalling, Trouble Starting #6
Thanks for the reply and the fix information. My eMax25 has been a Godsend after our huge ice storm we had here in Northern Lower Michigan. Purchased an HLA grapple and have been piling on the hours! Thanks again!
2010 Transcraft 35ft. Tri-Axle Aluminum End Dump Trailer (A64556)
2010 Transcraft...
2015 International DuraStar 4300 Elgin Broom Bear Street Sweeper Truck (A64556)
2015 International...
121A (A63745)
121A (A63745)
2022 EZ-GO ELITE...
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
