eMax 25 HST Unknown Valve
   / eMax 25 HST Unknown Valve #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
I noticed a valve under the HST pedals. The owners manual has nothing about it. The nut rotates 90 degrees, stop to stop.
What is it?
   / eMax 25 HST Unknown Valve #2
I’m not an emax guy but it should be fairly easy to track the hoses. I assume it’s to the loader based on the picture. Does it have a BH or something else in the rear? Does your loader valve use cables or is it right at the joystick?
   / eMax 25 HST Unknown Valve #3
That is just a hydraulic block that provides Pressure, Power Beyond and Tank lines to the tractors that are fitted with a loader.
For the non loader tractors, the spool is flipped to the left and therefore closing the circuit so it will power the remotes and 3 pt hitch. The top hoses are removed and the block is capped with a plug instead.
   / eMax 25 HST Unknown Valve #4
Possibly speed descent control for your 3 point?
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
Kubota SVL97-2 (A50120)
Kubota SVL97-2...
1994 GMC Top Kick Grain Truck (A50514)
1994 GMC Top Kick...
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2006 Poly-Coat Tanker Trailer (A50774)
2006 Poly-Coat...
