eMax 25 HST Unknown Valve
   / eMax 25 HST Unknown Valve #1
rdinatal
Lake Normanopolis, NC
Old: 2016 eMax25s HST, New: 2017 Max 26xl HST
I noticed a valve under the HST pedals. The owners manual has nothing about it. The nut rotates 90 degrees, stop to stop.
What is it?
   / eMax 25 HST Unknown Valve #2
I’m not an emax guy but it should be fairly easy to track the hoses. I assume it’s to the loader based on the picture. Does it have a BH or something else in the rear? Does your loader valve use cables or is it right at the joystick?
   / eMax 25 HST Unknown Valve #3
That is just a hydraulic block that provides Pressure, Power Beyond and Tank lines to the tractors that are fitted with a loader.
For the non loader tractors, the spool is flipped to the left and therefore closing the circuit so it will power the remotes and 3 pt hitch. The top hoses are removed and the block is capped with a plug instead.
   / eMax 25 HST Unknown Valve #4
Possibly speed descent control for your 3 point?
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A52748)
2019 New Holland...
Ziehl-Abegg Fan (A47384)
Ziehl-Abegg Fan...
H & S High Capacity Hayrake (A50515)
H & S High...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
