Elevation = rough start up..?
/ Elevation = rough start up..? #21
Perhaps I am wrong, but I thought a diesel most always operates with excess air (or O2) as the intake has no restrictions. You control the rpms or power with the "throttle" by giving it more fuel in the fuel injection charge rather than more air (like a gas engine). My guess is that this elevation change has nothing to do with starting but it is more temperature related. However Turbo chargers do help diesels at elevation more than at sea level as they can out of excess air at the lower atmospheric pressure and O2 levels under heavy engine load conditions.
Thank you for all the responses. Yesterday, after fluids and filter checks and a lube job I fired up the little beast. Temperature was 38˙, but with snow flurries happening I suspect colder. With 15 seconds on the glow plugs and a slightly elevated throttle ignition was immediate, as always, but again, warm up was rough for about 45 seconds. It did smooth out a bit quicker, probably due to increased throttle, which was only about 500 rpm above usual idle. Machine ran great after a ten minute warm up at normal throttle.
/ Elevation = rough start up..? #23
I use diesels at 10K feet in wyoming. There is no special injectors for this elevation, just give it some more air (throttle).
Diesel throttle controls fuel. Air is never restricted.
/ Elevation = rough start up..? #24
/ Elevation = rough start up..? #25
Yes, The turbo has the ability to "bootstrap" the power up to the fuel limit setting of the injector governor. The turbo just spins a little faster to shove in more of the thinner air.
/ Elevation = rough start up..? #26
Yes that is true, there is no throttle plate in a diesel.
However, throttle is a function of rpm on a diesel and rpm has a air component.
/ Elevation = rough start up..? #27
And it is all dependent on the burning of fuel. Air volume per revolution is the same except in turbo equipped engines where boost has developed.
/ Elevation = rough start up..? #28
Some Kubotas have indicators to tell you when sufficient Glow Plug time has elapsed. 10 sec seems short.
Try 20-25 Secs with more than idle Throttle setting.
/ Elevation = rough start up..? #29
I live at 8500 ft MSL. None of my three Kubortas [normally aspirated] has had any problems due to the elevation. It does get cold here at times, and sometimes I've had to run the glow plug several cycles before the engine fuel would fire off. My previous two tractors had the type of glow plug control I had to hold "on" and the new one determines how long to preheat then shuts off. However, if I cycle the key, it will go through the same timed cycle again. I have had to do this as many as four times in below-zero weather.
/ Elevation = rough start up..? #30
This past summer I transported my 2019 LS MT125 from sea level in Oregon to my Idaho mountain property at 3,200' elevation. Immediately cold start ups were rough and smokey. After a bit of warm up it smoothes out and all is good. Now that cooler weather is here the start ups have been noticeably rougher, to the point I believe the motor will just die. Hasn't happened yet, but definitely a concern. I've applied the ten second plug preheat, maybe more is needed...? Incidentally I've just 78 hours on the machine.
My thoughts are the map for the fuel injection needs to be upgraded... I have been under the impression ALL modern fuel injection maps were programmed for elevation changes. Any body have any thoughts on this and anyone operate at simliar elevation.
I have a JD 1025R with over 600 hours and it starts fine in the summer with the preheater used once and the fuel/air at about halfway. I'm at 750' above sea level. In the winter when it gets to -10 to -30 below I use the preheater 3 or 4 times and it starts fine. I have not had any starting problems until I learned to give it more fuel/air and more preheat times. When I don't use the tractor for a while I put a battery maintainer on to keep it ready to start. I have a 54" snowblower and a ballast box on the 3 point hitch to balance the load.
/ Elevation = rough start up..? #31
Might wanna put some thiner oil in it....5w/40 instead of the summer weight oil that is in it. That may help it start easier. But cold engines all run rough for a time when starting cold/not plugged in
/ Elevation = rough start up..? #32
I live at 6850 elevation and I’ve never had to have any altitude adjustments.
/ Elevation = rough start up..? #33
In my truck with Cummins diesel, I used to have to plug in the block heater overnight when temps fall below 10 degrees. After switching to Rotella T6 synthetic oil, I haven’t yet had to use the block heater to start the truck.
/ Elevation = rough start up..? #34
I live at 7,000‘ and are lows are in the 20’s, now. Longer use of the glow plugs gives a smoother startup as does a little throttle. Once it starts increase throttle till the engine smooths out. Usually she does smoke at startup. I use Shell synthetic Rotella 10—40 And California ultra low diesel.
/ Elevation = rough start up..? #35
It seems that every diesel engine has its own little idiosyncrasies particularly when it comes to starting. My tractor for example needs a little glow plug help even up to about +70 degrees, at least on the first start of the day. I usually start at about 1/4 throttle and then idle down to 1000 RPM for warm up as soon as all cylinders are firing evenly. After 14 years I can just about guess what will be needed for a smooth start at any temperature. Experience is a great teacher.
Cold engines generally require a richer mixture for cold starts. You elevation change actually helps that. However cold air is more dense so you have to compensate for that with more fuel. It is entirely possible to "flood" a cold engine. Cranking for a few seconds with the fuel in cut off (if possible) will help in these situations.
Make sure your glow plugs are actually all functioning. Having a dead one or two will really take a toll (ask me how I know) Also battery condition plays a big part as well as starter condition. Mine needs to be cleaned and lubed every few years to keep it in tip top shape. Even more important as temps drop.
Fuel grade may play a part too, although I don't know if that will affect ignitability. Shouldn't be an issue at your current temps but if you plan on using at lower temps you might want to check into that as well as have some anti-gel additive on hand.
/ Elevation = rough start up..? #36
Diesels do not throttle the air like a gas engine. There should be no noticeable difference between the two altitudes.
/ Elevation = rough start up..? #37
Sorry to burst your bubble, but air is regulated on all engines. I know I am old, but even old gas burners using carbs had butterflies that somewhat controlled air mixture with fuel. Modern gas burners are fuel injected so mixture happens in the cylinder much like diesel engines. However the air is still regulated. There are lots of electronic things present on fuel injected gas burners measuring and regulating air mixture. Just thrown a few MASS air flow, IAC, TPS, the list continues.
/ Elevation = rough start up..? #38
I live in Idaho at 4500 foot and have no problem with my Kubota L5030 in the winter. However, I do have a block heater and a battery blanket installed. Helps in a huge way!
/ Elevation = rough start up..? #39
We sure engine isn’t getting a burp of bad fuel? Temps are getting colder, wide night-day cooling swings. If there’s a low fuel tank level that’s mostly air, it can pick up a few drops (or more) of condensation with cooling cycles and water settles to bottom of tank where effects are experienced for the first minute or so at start up.
/ Elevation = rough start up..? #40
I agree that diesels are easy to flood above sea level and suggest an under-recognized cause is a sticky butterfly in the intake tract. Throttle position sensor or someone haveing tinkered with idle mixture screws can also impair a proper stoichiometric air/fuel ratio & glow plugs might not fire below 1/4 throttle.
btw, beware of a lean run condition caused by a plugged tank vent that doesn't allow equalization between that and the fuel bowl vent in the injector pump.
Things really haven't changed that much since the old days. ;)
3Pt Hydraulic Post Driver (A66408)
3Pt Hydraulic Post...
Linx EQ07018RS 18ft Trailer (A65640)
Linx EQ07018RS...
Unload Auger Tube for John Deere Combine (A65640)
Unload Auger Tube...
1960 IH Farmall Cub Tractor (A66285)
1960 IH Farmall...
2022 HAULMARK 14' T/A ENCLOSED TRAILER (A65643)
2022 HAULMARK 14'...
65' Air Hose Reel (A66408)
65' Air Hose Reel...
