Backhoe Electronic ignition conversion
   / Electronic ignition conversion #1
eddie48
McDonough, NY
TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
I have an old (1974) 3 cylinder 3550 backhoe. Is there an electronic ignition conversion available for it? Is it a big deal to install?
Thanks, Eddie 48
   / Electronic ignition conversion #2
Thanks, Eddie 48
I converted my 3 cyl. 1970 Ford 3400TLB, and it was very easy.
"Petronix" kit as I recall.
   / Electronic ignition conversion #3
Thank you, both, for your help and information. I'll try it sometime over the winter.
Ed
   / Electronic ignition conversion #5
These conversions have been done extensively on old muscle cars and they always work out well. I think you will be pleased.
   / Electronic ignition conversion #6
I installed the Pertronix kit on a 3000 and it worked flawlessly for 13 years. Ive since sold that tractor so can't vouch for it now but will bet it's still running fine.
   / Electronic ignition conversion #7
I like Pertronix myself but I have had some troubles with their units. I think they are good for consumer use but fall short on reliability in commercial use.
If you use them hard every day they will fail. What fails I don't know. By hard I mean running 24/7 on a irrigation pumping unit motor. I've also seen the magnets fall out of the piece that fits under the rotor. Luckily I found them all inside the distributor and was able to hold them in place with a piece of scotch tape.
Often though they are the only conversion available and I wouldn't hesitate to use them. Go to their website http://www.pertronix.com/ aand figure out which unit will work. Google that part number as you can get unit's a lot cheaper online vs picking them up in a store.
FAKE (A52472)
FAKE (A52472)
UNUSED FUTURE BS72 72" HYD BOXBROOM SWEEPER (A57193)
UNUSED FUTURE BS72...
JCB 8035ZTS EXCAVATOR (A52707)
JCB 8035ZTS...
2008 Honda CR-V SUV (A55853)
2008 Honda CR-V...
2021 CATERPILLAR 906M WHEEL LOADER (A52707)
2021 CATERPILLAR...
UNUSED Bubble Aluminum Foil Reflective Insulation (A53117)
UNUSED Bubble...
