Backhoe Electronic ignition conversion
   / Electronic ignition conversion #1
eddie48
Gold Member
McDonough, NY
TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
I have an old (1974) 3 cylinder 3550 backhoe. Is there an electronic ignition conversion available for it? Is it a big deal to install?
Thanks, Eddie 48
   / Electronic ignition conversion #2
Thanks, Eddie 48
I converted my 3 cyl. 1970 Ford 3400TLB, and it was very easy.
"Petronix" kit as I recall.
   / Electronic ignition conversion #3
Thank you, both, for your help and information. I'll try it sometime over the winter.
Ed
   / Electronic ignition conversion #5
These conversions have been done extensively on old muscle cars and they always work out well. I think you will be pleased.
   / Electronic ignition conversion #6
I installed the Pertronix kit on a 3000 and it worked flawlessly for 13 years. Ive since sold that tractor so can't vouch for it now but will bet it's still running fine.
   / Electronic ignition conversion #7
I like Pertronix myself but I have had some troubles with their units. I think they are good for consumer use but fall short on reliability in commercial use.
If you use them hard every day they will fail. What fails I don't know. By hard I mean running 24/7 on a irrigation pumping unit motor. I've also seen the magnets fall out of the piece that fits under the rotor. Luckily I found them all inside the distributor and was able to hold them in place with a piece of scotch tape.
Often though they are the only conversion available and I wouldn't hesitate to use them. Go to their website http://www.pertronix.com/ aand figure out which unit will work. Google that part number as you can get unit's a lot cheaper online vs picking them up in a store.
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
UNUSED FUTURE FTX1200 STAND-ON MUD BUGGY (A57192)
UNUSED FUTURE...
2023 Kubota L6060HST Compact Utility Tractor (A55315)
2023 Kubota...
