Electrically dead Boomer?
   / Electrically dead Boomer? #1
Ssequels
New Jersey
Boomer 40, Deer 2210, Ford 8N
I just purchased a Boomer 40 a few weeks ago and so far it was a good tractor. I was cleaning some things near my tractor and the instrument panel ended up getting hosed over. Probably should have been move careful, but didn't think a bit of water would hurt things. Afterwards, the keyswitch would not engage the starter, but it would make some of the dash lights flash. I decided to let it sit overnight in case it needed to dry. Since then nothing. I still have 12.9 volts on the battery, but no electrical activity. I checked small fusebox under the left panel and those are fine. The manual shows a 50amp maxifuse somewhere near the starter and have not located that one yet. There are quite a few relays under the dash. Is there a way of testing them? I'm pretty handy with my old Ford 8N, but this one has me confused.
   / Electrically dead Boomer? #2
Welcome
I would start by taking both battery cables off and wire brushing both sides of cables and attachment points, then reconnect & try again
   / Electrically dead Boomer? #3
A blown fuse would be a cheap fix but I don't think that's it. It is possible you still have moisture somewhere that's not evaporated. If your tractor is run by a computer this could be worse than you imagine. Most tractors can take sitting out in the rain but I have no idea what direction your water spray could have come from or the amount of force behind it. Figuring that out will go a long way toward deciding where the water got in. Water and electricity don't mix well.
   / Electrically dead Boomer? #4
Do you have an operator's manual? They often have wiring diagrams in them. Otherwise see if you can find a shop manual or may be someone who has a wiring diagram will post it for you.
2017 Ford Explorer AWD SUV (A46684)
2017 Ford Explorer...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A46683)
2009 Peterbilt 384...
2017 Chevrolet Impala Sedan (A46684)
2017 Chevrolet...
LoadMaster 23ft Tri-Axle Boat Trailer (A48082)
LoadMaster 23ft...
Lyom-053 Unassembled Safety Basket Forklift Attachment (A46683)
Lyom-053...
2013 Nissan Sentra SL Sedan (A46684)
2013 Nissan Sentra...
